Results 1 to 5 of 5
Thread: Smokin Patrol
    Jun 2018
    Smokin Patrol
    Gidday all,
    My 98 Patrol (TD42) with aftermarket turbo, sometimes burns alot of oil at a cold start. Seems to only happen consistently on cold mornings.
    Will be checking glow plugs, but I think it may have something to do with PCV.
    Runs well apart from that, although seems a bit sluggish.
    When it does burn oil, takes a minute or 2 to start running clean, and then runs well.
    Any advice.
    461 Post(s)
    Valve stem seals I would think. When the motor is off oil is leaking past the seals and into the cylinder. The oil then is burnt away after start up. Or maybe the turbo is leaking oil. Remove air outlet pipe on the turbo when it normally blows the smoke and see if its full of oil.
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    G'day mate and welcome to the forum. I also think valve stem seals for what it worth.
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
    Legendary happygu's Avatar
    Depends on what colour the smoke is for a Diesel, as to what it is.
    Black Smoke is usually Overfuelling
    White Smoke is Unburnt Fuel
    Grey/Blue Smoke is Oil Burn
    Are you losing oil on the dipstick, or are you just thinking that any smoke is oil burn
