Results 1 to 2 of 2
Thread: Diagnostic Plug
    May 2018
    Diagnostic Plug
    I have made a simple standalone diagnostic plug which when plugged into the 16-pin OBD port will cause the dash to flash the Engine light and read out the diagnostic trouble codes (DTC).
    Nothing special, but a convenient and easy way to extract the fault codes.
    This will only show error codes for the ZD30 DI 3.0L (pre-CRD only) engines built between 2000/Feb to 2006 inclusive that have the 16-pin OBD port.
    NOTE: The 2007+ ZD30 CRD will not work.
    This will work for both the Patrol and Navara D22 with the ZD30 DI (pre-CRD).
    I will include a leaflet with instructions and a list of the error codes.
    Price is $25. FREE postage to anywhere in Aus. PM me if you'd like one.
    Cheers.
  2. #2
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    It may be simple - but a piece of wire to short between Pins 1 and 8 is simpler - and does not cost $25.00. Thanks for the idea - but - nuh.
Tags for this Thread
