14th June 2018, 03:21 PM
Smokie TD42
Hi there,
I have a smokie nissan patrol, maybe someone here can help
1997 GU Coil Cab Chassis, TD42 with aftermarket turbo
I think it might be related to the PCV, but I am not sure.
Any advice?
14th June 2018 03:21 PM
14th June 2018, 06:09 PM
Administrator
Welcome to the forum mate, I have moved your post to here so others can see it.
What colour is the smoke, blue, black or white?
Does it smoke only on start up and go away or all the time, only under load?
26th February 2019, 02:29 PM
Hi AB, I have the same problem, Black and under load.
26th February 2019, 08:14 PM
Patrol Guru
RDG
Black smoke usually relates to fuel. Black smoke under load sounds totally normal for a diesel. Especially if it's had any work done to it.
26th February 2019, 09:30 PM
Daily Lurker
take a look at the forum mag, from a couple of years ago, there is a whole section in there about diesel smoke
27th February 2019, 12:16 AM
rusty_nail
There use to be a stickey to hey..im on me phone fark it all bit the pc showed ahitloads more
27th February 2019, 12:17 AM
Qhy my deisel smokes i 5gunk its called
22nd March 2019, 01:53 AM
#8
Some amount of black smoke sounds normal for a diesel if it's under load. There is usually some fuel left behind that isn't fully burnt.
