Results 1 to 8 of 8
Thread: Smokie TD42
    Jun 2018
    Smokie TD42
    Hi there,
    I have a smokie nissan patrol, maybe someone here can help
    1997 GU Coil Cab Chassis, TD42 with aftermarket turbo
    I think it might be related to the PCV, but I am not sure.
    Any advice?
    581 Post(s)
    Welcome to the forum mate, I have moved your post to here so others can see it.
    What colour is the smoke, blue, black or white?
    Does it smoke only on start up and go away or all the time, only under load?
    Feb 2019
    Hi AB, I have the same problem, Black and under load.
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Quote Originally Posted by RDG View Post
    Black smoke usually relates to fuel. Black smoke under load sounds totally normal for a diesel. Especially if it's had any work done to it.
  6. #5
    take a look at the forum mag, from a couple of years ago, there is a whole section in there about diesel smoke
  7. #6
    There use to be a stickey to hey..im on me phone fark it all bit the pc showed ahitloads more
  8. #7
    Qhy my deisel smokes i 5gunk its called
  9. #8
    Mar 2019
    Some amount of black smoke sounds normal for a diesel if it's under load. There is usually some fuel left behind that isn't fully burnt.
