Results 1 to 3 of 3
Thread: gu ute 2012 panhard bush adjust
    Sep 2017
    Question gu ute 2012 panhard bush adjust
    Hi
    Has anyone seen one of these before?
    I have the 80kph wobbles and the panhard bushes look a little tired but it has this adjustment that I haven't seen before and suspect that special bushes are required.
    I hope the picture worked this is my first time...
    It is fitted to a 2012 gu coil ute with a 50mm lift.
    Sep 2017
    Thanks to a facebook group. It is a lock nut. Issued as a recall on late model patrols. Seems super complex doesn't it.
    Yep, over engineered to the max. I suggest you obtain a black rubber replacement bush because they tend to show they are stuffed where as I have been advised neoprene ones last but fail without much warning.
