Results 1 to 9 of 9
Thread: Search Options
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Search Options
    Is there any way you can search a complete sentence or multiple words on the forum?
    If I use the 'Advanced Search' option and type in 'block egr crd' in 'Search Titles Only' it returns all titles that contain either 'block', 'egr' or 'crd'. Unfortunately not very user friendly.
    I'm looking for the post called something like 'You Look Like The Guy From' and can't find it either.
    Jack
    Patrol Guru rkinsey's Avatar
    Sep 2010
    Minchinbury
    Gday jack,
    Depends on what you are looking for. To use any search engine like how you are describing, put the words or sentence inside parenthesis (Quotation marks) " bla bla bla "
    I did a search using "block egr crd" and it found this very post but none others.
    Try changing your search terms to widen the search or if you know of a specific unique word or sentence then use that.
    Hope this helps.
    Cheers,
    Rob
    Just about to jump into my next Patrol. A 2001 GU II TB45E .
    WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
  4. The Following User Says Thank You to rkinsey For This Useful Post:
    jack (29th May 2018)
    Ballarat Area
    25 Post(s)
    Thanks Rob, I’ve already tried using parentheses without success. I know there is a lookalike thread on here that hasn’t been posted in for sometime and I’ve tried just about everything to find it.
    Hate to say it but I like the search algorithm on Patrol 4x4
    Jack
    174 Post(s)
    Found it .......... but only by searching for a single word ............'catweazle'. Ha Ha.
    http://www.nissanpatrol.com.au/forum...that-dude-from
  7. The Following 3 Users Say Thank You to Cuppa For This Useful Post:
    jack (30th May 2018), mudnut (30th May 2018), rkinsey (30th May 2018)
  8. #5
    Ballarat Area
    25 Post(s)
    Thanks Cuppa, but that doesn't help with simplifying the search process. I often see members recommend to new members to use the 'search function' but that's not much help.
    Maybe a job for @AB
    Jack
  9. #6
    Maybe a job for @AB
    You really like poking the bear with a sharp stick, don't you Jack. Remember what happens when Andy tinkers with the forum!!!!
  10. The Following User Says Thank You to mudnut For This Useful Post:
  11. #7
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    You would probably find the search function between us and them exactly the same, they actually use an older version of vBulletin than what we do. Maybe its because someone on there has tagged there post and on here it hasn't been tagged.
  12. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  13. #8
    22 Post(s)
    Using google itself is better in this configuration.
    Egr block crd site:www.nissanpatrol.com.au
    If you know who which user said the exact piece of info you're looking for, just add the username to it.
    It must end with "site:www.etc etc.com.au" Google will only search on web page added.
    Don't forget the colon : after 'site'
    96 GQ coil/Cab
    08 G6eT
  14. The Following 4 Users Say Thank You to Ben-e-boy For This Useful Post:
    clawrence (31st May 2018), Hodge (30th May 2018), jack (30th May 2018), mudski (30th May 2018)
  15. #9
    Ballarat Area
    25 Post(s)
    Thanks Benny, works a treat - learn something new everyday (at my age that's a bonus)
    Jack
