Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: wiring rear worklights from roof rack
    Expert Ibbo's Avatar
    Mt Barker, SA
    Yep good point MB. Might look to do that. Still only a half done job but tools down for tonight. Was glad to finally see the wiring on the inside of the vehicle after mucking around with it all afternoon.
    2010 GU, 2in lift, old man emu suspension, duellers, arb bullbar, dual batteries, safari snorkel, scangauge2, rhino rack platform, saving for more......
  2. The Following User Says Thank You to Ibbo For This Useful Post:
    MB (25th May 2018)
    Mt Barker, SA
    How does this look MB? Alot neater and stronger I reckon. Thanks for the advice.
  5. The Following User Says Thank You to Ibbo For This Useful Post:
    MB (27th May 2018)
  6. #13
    472 Post(s)
    Heaps nicer lbbo mate!
    Best to make sure you’ve got a suitable size elecy fuse in the cab too for added peace of mind. Never ceases to amaze me out there what sneaky trackside flora tries to do to our trucks :-)
  7. #14
    194 Post(s)
    I think the first tree branch coming down the side of your truck is going to hook thru that wiring and tear it out. If you don't do much close quarter brushy stuff this might be OK, but would not think it would last long in Vic high country. The cable needs to be better protected for over here. Hiding it behind a snorkle as MB showed initially is perhaps the better concept. Hope this helps!!
  8. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Ibbo (27th May 2018), MB (27th May 2018)
  9. #15
    Mt Barker, SA
    Thanks PB. It is pulled in against the car now and the roof rack sits out proud of that so will probably lose the work light and get some serious pin striping if it catches the wiring. Will see how it goes. Simpson desert is the most immediate trip I am getting prepared for and should not be an issue out there.
  10. The Following 2 Users Say Thank You to Ibbo For This Useful Post:
    MB (27th May 2018), PeeBee (27th May 2018)
  11. #16
    472 Post(s)
    Simpson desert, that’ll be awesome mate! Safe travels and do enjoy, very jealous here!
    Wedgetail Eagles searching for a baby Black Snake feed should be your only elecy worries out there :-)
  12. The Following User Says Thank You to MB For This Useful Post:
