24th May 2018, 05:01 PM
Travelling Podologist
Torque setting for hub centre bolts needed urgently!
I've searched the manual & can't find out how tight to do up the bolts on the rear hub centre on my leaf sprung ute. Can anyone help please?
24th May 2018 05:01 PM
24th May 2018, 06:03 PM
Moderator
RA-6
118 - 147 N-m
12 - 15 kg-m
87 -108 ft-lb
Check out my Toy -->
Rogue Dung Beetle
24th May 2018, 06:05 PM
Smart like tractor
Axle shaft Retaining nuts.
53-63Nm as per my gregory's manual
96 GQ coil/Cab
08 G6eT
MudRunnerTD (24th May 2018)
24th May 2018, 06:06 PM
Moderator
MudRunnerTD
RA-6
118 - 147 N-m
12 - 15 kg-m
87 -108 ft-lb
Although that is a Coil sprung Rear wagon. and it seems that is the wheel nuts? hmm let me see if i can find something Ute specific? clearly that is different to a Wagon. that is almost a Toyota 80 series setup cuppa? is that your ute mate?
Rogue Dung Beetle
24th May 2018, 06:16 PM
Smart like tractor
MudRunnerTD
H260 leaf sprung full floater. They're bolts and the manual does state nuts which would assume a h233 noted, but they are of similar size so that torque setting could be used, just monitor it regularly and re-tension if required
96 GQ coil/Cab
08 G6eT
24th May 2018, 06:25 PM
MudRunnerTD
RA-6
118 - 147 N-m
12 - 15 kg-m
87 -108 ft-lb
Thanks Darren & Ben, That's what I first thought, but those are for the wheel studs.
I had made the same mistake & tried doing the hub centre nuts up to 100ft-lb but chickened out (thankfully) at 80 & even that felt far too much. I then realised my mistake & loosened them off, luckily no stripped threads.
Yes for my ute. Seems utes are a different breed in many ways to wagons.
Have just finally found the diagram at Feb '99 Supplement 2 1st Revision Rear axle full floating type RA7 ...... 36 -42 ft lbs ...... it's only taken about an hour to find it! Nissan manuals are a nightmare, I had almost given up the search.
24th May 2018, 06:35 PM
For anyone who needs this info in the future (& to help me find it again if I need it!)
The Following 2 Users Say Thank You to Cuppa For This Useful Post:
AB (24th May 2018), MudRunnerTD (24th May 2018)
24th May 2018, 06:45 PM
Administrator
I'm loving the internet speed in the hills!
I saw Cuppas post 1 hour ago and tried to download the manual as I thought I saw it there a while ago and it just finished downloading now
Annnd after all that the manual was in another folder!!!!!!!!!!
