Results 1 to 8 of 8
Thread: Torque setting for hub centre bolts needed urgently!
    Ballarat, Vic
    174 Post(s)
    I've searched the manual & can't find out how tight to do up the bolts on the rear hub centre on my leaf sprung ute. Can anyone help please?
    A Nomadic Life (Blog)
    330 Post(s)
    RA-6
    118 - 147 N-m
    12 - 15 kg-m
    87 -108 ft-lb
    22 Post(s)
    Axle shaft Retaining nuts.
    53-63Nm as per my gregory's manual
    96 GQ coil/Cab
    08 G6eT
  5. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    MudRunnerTD (24th May 2018)
  6. #4
    330 Post(s)
    RA-6
    118 - 147 N-m
    12 - 15 kg-m
    87 -108 ft-lb
    Although that is a Coil sprung Rear wagon. and it seems that is the wheel nuts? hmm let me see if i can find something Ute specific? clearly that is different to a Wagon. that is almost a Toyota 80 series setup cuppa? is that your ute mate?
  7. #5
    22 Post(s)
    H260 leaf sprung full floater. They're bolts and the manual does state nuts which would assume a h233 noted, but they are of similar size so that torque setting could be used, just monitor it regularly and re-tension if required
    96 GQ coil/Cab
    08 G6eT
  8. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  9. #6
    Ballarat, Vic
    174 Post(s)
    RA-6
    118 - 147 N-m
    12 - 15 kg-m
    87 -108 ft-lb
    Thanks Darren & Ben, That's what I first thought, but those are for the wheel studs.
    I had made the same mistake & tried doing the hub centre nuts up to 100ft-lb but chickened out (thankfully) at 80 & even that felt far too much. I then realised my mistake & loosened them off, luckily no stripped threads.
    Yes for my ute. Seems utes are a different breed in many ways to wagons.
    Have just finally found the diagram at Feb '99 Supplement 2 1st Revision Rear axle full floating type RA7 ...... 36 -42 ft lbs ...... it's only taken about an hour to find it! Nissan manuals are a nightmare, I had almost given up the search.
  10. The Following User Says Thank You to Cuppa For This Useful Post:
  11. #7
    Ballarat, Vic
    174 Post(s)
    For anyone who needs this info in the future (& to help me find it again if I need it!)
  12. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    AB (24th May 2018), MudRunnerTD (24th May 2018)
  13. #8
    581 Post(s)
    I'm loving the internet speed in the hills!
    I saw Cuppas post 1 hour ago and tried to download the manual as I thought I saw it there a while ago and it just finished downloading now
    Annnd after all that the manual was in another folder!!!!!!!!!!
