Results 1 to 7 of 7
Thread: Diff ratio's
    Beginner NQ4x4's Avatar
    Apr 2018
    Townsville
    Diff ratio's
    Trying to find out what model GU engines had what diff ratio , is there a list some where for referance
    175 Post(s)
    This is straight off Marks adaptors website. So I don't take responsibility in accuracy.
    NQ4x4 (27th May 2018)
    462 Post(s)
    Not quite accurate. GU 3.0 Turbo Diesel Manual 4.11/1, Mine came out factory with 4.3's...
  7. #4
    Jeez, Mudski... On standard tyres it must rev its head off with a short diff like that.
    FWIW the Nissan specs on their brochures et al are as per the Marks numbers
    Top in the Manual box is 0.8 something intoa 4.1 diff and top in the Auto box is 0.6 something into a 4.3 diff.
    Would be goodo for 33's tho.
    BUT... as we all know... Nissan will put just about any diff in any truck without rhyme or reason.
  8. #5
    Oct 2017
    I believe all series 2 3.0ltr manual patrols had 4.3 gears in the diff.
    Series 3 wagons may also be the same (correct me if I’m wrong).
    Series 4+ manuals wagons had 4.1 gears
  9. #6
    Nov 2010
    Getting a life...
    38 Post(s)
    Just put a new diff in the GU Ute. (4.2n/a)It came from a wagon, (td42)both 4.11. I think Nissan just put in whatever they had on the day.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  10. The Following User Says Thank You to katwoman For This Useful Post:
    Yeti's Beast (26th May 2018)
  11. #7
    462 Post(s)
    It was when I did the TD transplant. 1st gear was virtually non existant. I'd take off in 1st and and hunting for 2nd as soon as I took off. Was fine with the ZD though. Now with 4.11's its much better. Still rev's a little high at 100ks in 5th for my liking though. 2450rpm...
