25th May 2018, 05:47 PM
#11
Patrol Freak
Lost_gq_td4.2
Yeh can be done but still should have good spark not weak spark can't even get a back fire out of it have checked timing more times than I've wanted to lol
Not always the case. If the shaft is out of alignment the points may be opening at a time when the rotor button is not properly lined up with one of the contacts for a HT lead. Again, I have not worked on a petrol Patrol so I can't say for certain. A workshop manual should show how to test the correct alignment.
BTW, what gap did you set the points at or did you use a dwell meter?
25th May 2018 05:47 PM
25th May 2018, 06:44 PM
#12
So you had someone stick their finger in the number one spark plug hole as you manually turned the engine over, to see that it was on the compression stroke? Or if you are by yourself, remove the other five plugs and manually turn the engine until you feel compression to make sure it is not 180 degrees out.
