Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Need help tb carby spark issues
    Mar 2017
    Rutherglen Vic
    Have recently changed motors over in my 89 GQ the 4.2 carby manual got a long motor minus dizzy and carby drove the car in to where I was working changed it all over put my dizzy and and carby on new motor but can't get it to run has very weak spark did have a pentrix in it changed back to brand new points and condenser and new coil and still nothing have tried another pentrix out of another running car and still no good has 12.6 volts and the battery and a 11.9 at the coil it's doing my head in thanks
    The master farter
    mudski's Avatar
    461 Post(s)
    Checked all earth points to and from the motor and batteries? All electrical connections making clean and making good contact? Maybe run a separate earth strap from the -ive on the cranker to the engine block?
    Mar 2017
    Rutherglen Vic
    Yeh have double checked earth's but going to go back though every thing to nite to make sure I haven't missed any thing
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    The initial voltage on start up should be petty close to battery voltage. Page 12-14 of the Haynes manual (1988 models) shows the coil receives a reduced voltage when running, via a resistor.
    Page 12-15 (1990 and earlier models) shows you get full battery voltage at the coil on start up and running via a link in the switch. It also provides a signal to the Engine Revolution Unit via the blue wire between the distributor and coil..
    Check the voltage on the Red and /or White/black wires (depending on which style wiring you have) at the ignition switch.
  6. #5
    Mar 2017
    Rutherglen Vic
    Ok will check behind the switch tomorrow had a bit more of a play changed some earths and that and now starting to get blue spark still not big spark but it's a start
  7. #6
    Mar 2017
    Rutherglen Vic
    So checked behind the switch had battery voltage but winding it over would drop to 7 to 8 volts and was the same at the coil so wired in a relay to the coil so getting full voltage but only getting max of 9 volts coming out of the coil and wasn't really constant so really has me screwed
  8. #7
    SW Vic.
    80 Post(s)
    All I can suggest is check the wires between the coil and distributor. Check the internal distributor wiring.
    I have heard that some non genuine distributors are made of an alloy that doesn't earth properly so humour me and try clipping a lead from the distributor body to an earth on the chassis.
  9. #8
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Had a similar problem with a different vehicle years ago and found the distributor shaft was 180 degrees out. Don't know if that is possible to do with yours.
  10. #9
    Mar 2017
    Rutherglen Vic
    Yeh have checked earth on dizzy and its earthed inside and out as for wires from the pentrix I've pulled it from a running car
  11. #10
    Mar 2017
    Rutherglen Vic
    Quote Originally Posted by BillsGU View Post
    Yeh can be done but still should have good spark not weak spark can't even get a back fire out of it have checked timing more times than I've wanted to lol
