Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Need help tb carby spark issues
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Quote Originally Posted by Lost_gq_td4.2 View Post
    Yeh can be done but still should have good spark not weak spark can't even get a back fire out of it have checked timing more times than I've wanted to lol
    Not always the case. If the shaft is out of alignment the points may be opening at a time when the rotor button is not properly lined up with one of the contacts for a HT lead. Again, I have not worked on a petrol Patrol so I can't say for certain. A workshop manual should show how to test the correct alignment.
    BTW, what gap did you set the points at or did you use a dwell meter?
    So you had someone stick their finger in the number one spark plug hole as you manually turned the engine over, to see that it was on the compression stroke? Or if you are by yourself, remove the other five plugs and manually turn the engine until you feel compression to make sure it is not 180 degrees out.
