13th May 2018, 10:03 AM
Autotecnica guages
Hello all.
I am looking to fit some guages to my ute
2003 Intercooled DT42.
I was wondering if anyone has experience with Autotecnica guages as sold by Autobahn. I know that I am better off buying top of the line stuff, but at the moment cannot afford the outlay. I want to adust the standard turbo and pump to get what I can out of them. Eg, boost controller, guages to read changes and a pump tune. Probably an exhaust if I can find 1 at the right price.
Regards
Gavin
13th May 2018 10:03 AM
13th May 2018, 12:07 PM
RockyGav
Hello all.
Regards
Gavin
I use Saas from super cheap and all 5 gauges work fine cheers Alex
97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
13th May 2018, 04:32 PM
i had an autotecnica electronic oil pressure gauge in my 355vs ute found it was utterly useless and the reading would vary massively depending on the voltage it was recieving(had fridge in back and tripple batts
gone to the dark side 2017 vdj 79 dc
13th May 2018, 09:48 PM
Patrol Freak
I have autotechnica boost and EGT gauges.
The boost works fine while the EGT reads true for a while then bounces around for a while, then reads true again.
When I get my act together I will be replacing the EGT.
As I lay there looking up, taking in the spectacular view that was the night sky and the multitude of stars I asked myself, where did my tent go?
14th May 2018, 05:48 PM
Thanks all. I looked at SAAS, You can get a decent deal for 2 dual readout guages in a pillar bod. Also looking at VDO.
