Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Rear barn door won't open gu
    Apr 2018
    Hi all having problems getting rear left barn door open have tried pushing shaking banging ect is there a way to get it open from out side I carnt get to the inside have cargo barrier an a draw system or is time to get the grinder out an get a new door cheers
    581 Post(s)
    Have you tried pushing the right hand side door in hard first and then try to open it?
    If RHS is not locked properly LHS sometimes won't open.
    581 Post(s)
    Try pushing RHS door as you pull handle on LHS too?
    Apr 2018
    Cheers ile try that now
    581 Post(s)
    Hip and shoulder RHS as you pull handle.
    Apr 2018
    OK that didn't work it sounds like the lock its not working rite looking from outside it looks like it doesn't unlock all the way I have tried a rod through the cargo barrier to move it with no luck
    Legendary happygu's Avatar
    Is there anything in the back pushing up against the back door?
    I have had that before with my older GU's where I jammed stuff into the back and it was pressing on the Lock Button on the back door, as the older ones don't have any protruding material to stop the cargo being hard up on the lock itself.
    I had to go for a drive - a bit of rough cornering and hitting the brakes hard to slide everything away from the door
  9. The Following User Says Thank You to happygu For This Useful Post:
    AB (8th May 2018)
  10. #8
    Apr 2018
    No nothing against the doors
  11. #9
    581 Post(s)
    Would it be worth a try to get a long rod from inside the cab to see if you can push the lock up and down inside maybe?
  12. #10
    Apr 2018
    Can get the rod in there but doesn't work .had thought if breaking the window an trying it
