Results 1 to 10 of 17
Thread: Replace leaking fuel pump. Yikes!!
    Feb 2018
    I took my 2008 3.0L Deisel GU in to see if my mechanic could find out why it seems to lose power when towing uphill. Thought maybe the turbo wasn't boosting or something......
    He said no problem with turbo and could see any loss of power.
    BUT....
    He did say there was a leak from the fuel pump! (And has nothing to do with the above background story)
    Now I am about to go on a 3 month trip up to the cape, the swamp and the rock towing a small Jayco, and according to my mechanic I definitely don't want to do that with a leaky fuel pump.
    The cost to replace is estimated at around $3000, which is going to put a huge dent in our budget, and after spending about $8k on mods and accessories for the trip already, this is not what I wanted to hear 4 weeks prior to lift off.
    He tried to show me where the leak was, but I couldn't see anything significant at all. I have used this same mechanic for years and dont think he will try to rip me off, but ouch!
    Has anyone had to do this and is the $3k estimate reasonable?
    Is a leaky fuel that critical that I should do it before the trip?
    Any advice, recommendations and suggestions welcome!
    Ballarat, Vic
    174 Post(s)
    I wouldn't be comfortable to take a vehicle which isn't right on a long trip to remote areas. You might get away with it, but if you don't it could cost a heck of a lot more than getting it fixed before you leave. If the cost is $3k at home, think double that up on the Cape plus the inconvenience & costs associated with the time it takes (sending away a pump to be rebuilt might take weeks).
    Either trust your mechanic or get a second opinion on the fuel pump.
    Power loss might be sensor related? Others with 3.0 litre Patrols might comment more authoritatively than I can, but if that is the problem, the solution can be fairly easy & cheap.
    Check all intercooler hoses are tight & that you have no intercooler leaks.
  4. The Following User Says Thank You to Cuppa For This Useful Post:
    neilo99 (30th April 2018)
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Just got my 4.2td injector pump done for the same trip and not much more than that I thought the 3 litre was much cheaper but after having a leaking pump through corner country it wasn't much fun not knowing if we were about to breakdown or not .
    I'd get it done but if you want peace of mind go to a specialist diesel injector pump repair shop if you have one nearby and get a second opinion and price .
    Cuppa is right if you need towing where you're going it'll cost a damn sight more .
  6. The Following User Says Thank You to GQtdauto For This Useful Post:
  7. #4
    Feb 2018
    Thanks. Will definitely look for local specialist for a second opinion. Dont need the stress out there.......
  8. #5
    462 Post(s)
    Out of interest. Do you run a boost gauge? If so, does it hold boost when under load? Is the intercooler the original intercooler? What mods have you done to the motor?
  9. #6
    Feb 2018
    Nope. No boost gauge.
    I've only had it for a few months and as far as I am aware no mods have been done to the motor.
    Is there any way to check the boost without a gauge?
  10. #7
    462 Post(s)
    Quote Originally Posted by neilo99 View Post
    No, a boost gauge can be temporarily put in though. Reason for my asking, is poor performance can be due to a leaking intercooler. Sometimes the leak is not so prevalent whilst not under load and normal driving so its no so noticeable. If you run a boost gauge you can monitor boost levels and see whats going on.
    So have a look at the intercooler, best to remove the plastic engine cover, if the end tanks are crimped to the core of the cooler, like a genuine radiator is, its the original intercooler. If it is, have a look and check to see if there is any oil deposits on the core of the intercooler. Particularly when the crimps are. Its best to check the bottom side too. If you see any oil wet spots, thats a very high probability that the intercooler is leaking.
    So, what damage can be had from a leaking intercooler? On a stock system where boost is controlled via the factory control solenoid, the turbo will have to work harder to compensate for the boost loss. So extra fuel will be used and extra, unnecessary wear and tear on the turbo.
  12. #8
    Feb 2018
    Thanks @mudski!
    Will def be checking that in the morning!
  13. #9
    175 Post(s)
    Hello neilo99.
    Your mechanic , isn't far of around $3k for the work.
    When I was in that scenario brand new genuine Bosch pumps were $1200-1300.
    Injector lines which need to be replaced were around 200-300 together with benching fitting and calibrating to the ECU.
    For what it's worth mate. I used to own a 2009 3l crd. Since day 1 I've had small "sweat" of diesel from some where on the common rail pump.
    It was clearly visible. I've had it looked at and got told not to worry about it. It did not impact performance. I still know the guy who owns the car and to this day, the pump is sweating diesel and the car is still going without a hiccup.
    In my honest opinion your loss of uphill power is nothing to do with the pump. If you had pump issues you would know about it way before you got to that hill mate...
    HOWEVER, in saying that, like others have said , I would not go outback if car was not tip top. Including a sweating IP.
    Mudski is spot on. Check your boost. Factory boost control is shit. I repeat , Shit! It's a fluctuating boost yoyo. Once I tamed the boost with a needle and Dawes valves , the car was an entirely different beast. Boost was smooth and linear with the foot pedal and predictable.
    There is also a rail pressure relief valve which can release all diesel pressure back to the return lines under some load circumstances ... Once this valves pop for the first time , they tend to keep doing it until replaced. I had similar symptoms on my crd and this valves fixed all that .
    This possibly could be your issue too.
  14. The Following User Says Thank You to Hodge For This Useful Post:
    neilo99 (1st May 2018)
  15. #10
    Feb 2018
    Thanks @Hodge. I do suspect boost is the problem. The pump leak was found while troubleshooting the boost, and is probably unrelated like you say.
    I will look into getting both sorted...
