Results 1 to 7 of 7
Thread: GU (ZD30) Bash Plate help (EDS Fabrication)
    Feb 2018
    Post GU (ZD30) Bash Plate help (EDS Fabrication)
    Okay, got given this bash plate for sump protection on a ZD30 today.
    Thing was cheap as however the only catch to a mad deal is:
    1. No fitting instructions
    2. No kit/box
    3. No part codes
    What do i have? an EDS Fabrication sticker on the bottom, and a directional sticker on the top to point the thing to the front of the car. It also has a filthy big hole to that presumably aligns with the sump plug and its stepped in such a way that when layed next to the front axle, it sits above it and fits.
    Has anyone got one of these, fitted one, seen one, anything really?
    I have spent the afternoon trolling through forums, web searches, manufacturer sites etc. The only thing that I haven't done is called EDS Fabrications, because they wont answer their phones and clearly have not checked their answering machine. On that note EDS fabrications have a website that merely says they manufacture for Opposite Lock, UV 4x4 and then some fleet companies, both these brands have nothing looking like mine so am again stumped.bash plate.jpg
    462 Post(s)
    whats that sticker say?
    Feb 2018
    'Front, passenger, driver, rear' pointing in the appropriate directions. Basically they beg circle cut out at one end is the front aligned to be above the diff house
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    I believe it says front ,back pass side drivers side .
    I'd just crawl underneath to see if I could nut it out .
    462 Post(s)
    Yup. Its only gonna fit one way....
    581 Post(s)
    Have a crack mate, get underneath and see how it works and if still stuck take pics and let us know.
  8. #7
    Feb 2015
    Dartmoor, England
    You're right, that's a sweeping great hole in that rear part!
