Results 1 to 10 of 10
Thread: New 'used' nissan clock in GQ
    Legendary
    194 Post(s)
    OK, installed the clock and presto, lights up with ignition on the first, second and third time, then couple of days later, nothing. Car on and off, headlights on off, hit 'reset button' 5 sec, 10 secs, nothing, then next day, clock is on with ignition??? Checked and swapped out fuse in case there was some corrosion, or a repeat of a recent issue with poorly seated fuses that stopped the car. Connector is 'home' as there is a distinct 'click' made when the two parts of the plug assy are fitted.
    Any ideas guys?
    Legendary
    194 Post(s)
    Post closed for now. The wrecker in QLD has kindly refunded my money, so still looking for a dash clock.
    Super common issue with the GQ clocks. Caused by dry solder joints. Have a google of it and there are plenty of people who have repaired them.
    Haven't had an issue with mine in both of my GQ's.
    Sent from my SM-T385 using Tapatalk
  5. The Following User Says Thank You to Winnie For This Useful Post:
    PeeBee (23rd April 2018)
  6. #4
    192 Post(s)
    Yeah same always been lucky with mine but common for them to fail. Bugger didn't last very long. . .
  7. The Following User Says Thank You to Rossco For This Useful Post:
  8. #5
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    mine works sometimes when i get around to it i'll open it up and find out why.
  9. #6
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Same, only thing in my GQ that actually works
  10. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  11. #7
    Legendary
    194 Post(s)
    I have bought a couple of 40mm analogue cheapie clocks off ebay and will see if I can fix this one in the meantime, no hurry.
  12. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (23rd April 2018)
  13. #8
    472 Post(s)
    Do have to ask Philstar, why two or three mate, most of us Aussie’s carry a stick?
    Rossco (23rd April 2018)
  15. #9
    Legendary
    194 Post(s)
    Get a bit tiresome having to drive all the way out there just to read the time. Bought a couple of different types and sizes/style to see if any last longer than a week before crapping out. If VDO or similar made a clock in say 40mm or 44mm then it would slot straight into the hole and last a while, unfortunately can only find a 52mm variant and I am not that desperate to take a hole saw to the dash just yet.
  16. The Following User Says Thank You to PeeBee For This Useful Post:
  17. #10
    472 Post(s)
    “Tiresome’” ? , I’m sure you’d enjoy the ‘Simo’ better again in later life young mate ;-) !
    Buy oneself a stick and test the clockless joy they say honestly good man!!
