Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Converting elec windows to manual
    581 Post(s)
    Yes, it looks like aftermarket elec which worries me!!!
    you get 10 nissanpatrolforum points .....
    Redeemable in all mainland states and territories except WA, VIC, QLD, SA, NSW, ACT and NT.
    Cannot be used with any other offers, discounts, rebates, specials or reductions.
    Expire immediately on issue unless accompanied by a valid Credit Card, CIC and PIN.
  4. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    AB (21st April 2018), Avo (21st April 2018), GQtdauto (21st April 2018)
  5. #13
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    someones done some weird shit to ya door mate,,,
    Looks like I'm not the only one who gets exited bu Nissans !
  6. #14
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I'd say its just the mechanisms for the window has totally been removed looking at that pic and you should be able to remove your manual one from your door straight over
  7. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  8. #15
    581 Post(s)
    Confirming it is a straight swap over but you also have to remove the brace under the window itself as they are different.
    This is a slight PITA as there are little plastic tabs that are glued onto the base of the windows with nutserts that hold a bracket which holds the manual scissor type mechanism on the front windows being larger and a one way "scissor" type mech on the rear windows being smaller.
    They are very fragile being a 25 year old car and I snapped one damn it but it looks to be an easy swap over.
  9. The Following 2 Users Say Thank You to AB For This Useful Post:
    MB (22nd April 2018), mudski (22nd April 2018)
  10. #16
    581 Post(s)
    Unscrew the LHS mount of the door handle to take out the elec mech runner too, that took me a while to figure that out and the grinder may have come out before I worked that bit out!!!
  11. The Following User Says Thank You to AB For This Useful Post:
    Avo (22nd April 2018)
