Results 1 to 5 of 5
Thread: Cost of changing LPG tank back to unleaded. GU Patrol
    Apr 2018
    Queensland
    Now that LPG is becoming harder to get in country Queensland (probably Australia) I am wondering about the cost of changing existing LPG tank back to an unleaded tank
    2001 GU Patrol wagon 4500. I only get 4km per ltr when towing our van and one tank makes it a bit hairy.
    Not necessarily removing other gas fittings
    Many thanks
    PeteM384
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    2 Post(s)
    Hi Pete, have same patrol GU -97 -4.5 , 4 km per litre towing is fine as my 90 ltr tank give a range of 400kms without towing. try downloading lpg app for your phone , it shows all car lpg filling stations that are open . regards Alex
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
    Apr 2018
    Queensland
    Thank you Alex
    But cannot find the app. What is its full name please?
    Nov 2011
    Rupanyup, 3388, VIC
    2 Post(s)
    Hi Pete , the one I use is Fuel Map Australia (WikiCamps), you can use it to show LPG stations only or all , some stations show current prices too. cheers Alex
  6. #5
    Apr 2018
    Queensland
    Quote Originally Posted by altech View Post
    Thank you Alex, I have it but was obviously not using it correctly. PeteM
