20th April 2018, 09:32 AM
Cost of changing LPG tank back to unleaded. GU Patrol
Now that LPG is becoming harder to get in country Queensland (probably Australia) I am wondering about the cost of changing existing LPG tank back to an unleaded tank
2001 GU Patrol wagon 4500. I only get 4km per ltr when towing our van and one tank makes it a bit hairy.
Not necessarily removing other gas fittings
Many thanks
PeteM384
20th April 2018 09:32 AM
20th April 2018, 11:40 AM
Hi Pete, have same patrol GU -97 -4.5 , 4 km per litre towing is fine as my 90 ltr tank give a range of 400kms without towing. try downloading lpg app for your phone , it shows all car lpg filling stations that are open . regards Alex
97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
20th April 2018, 12:57 PM
Thank you Alex
But cannot find the app. What is its full name please?
20th April 2018, 04:33 PM
Hi Pete , the one I use is Fuel Map Australia (WikiCamps), you can use it to show LPG stations only or all , some stations show current prices too. cheers Alex
21st April 2018, 06:18 AM
altech
Thank you Alex, I have it but was obviously not using it correctly. PeteM
