Page 9 of 18 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 172
Thread: Back in a GQ
  1. #81
    Dec 2012
    Work
    Emuwings turned up today, it’s a shame I’m going away, install will have to wait till Sunday
    The adhesive has to cure for 24 hours, so if I pull out the cargo windows Sunday when I get home, then I can fit the actual gullwings during the week after work!
    Just another Blue over Silver GQ with another TD conversion
  2. The Following 3 Users Say Thank You to Reddave For This Useful Post:
    AB (15th February 2019), Avo (17th February 2019), MB (16th February 2019)
    Dec 2012
    Work
    Went away to Mt Disappointment over the weekend, just a camping trip so no low range work
    Then came home and pulled out my cargo windows, fitted the pinchweld and frames for the Emuwings , now just need to wait for the sealer to cure so I can fit the rest of it!
  5. The Following 4 Users Say Thank You to Reddave For This Useful Post:
    Avo (17th February 2019), MB (19th February 2019), Rossco (17th February 2019), rusty_nail (17th February 2019)
  6. #83
    Dec 2012
    Work
    Fitted the rest of the Emuwings after work, I’m going to have to rearrange the brackets for my soft luggage shelf as the hinges hit on it
    Modifying cars is super fun, one step forward, two steps back lol
  7. The Following 3 Users Say Thank You to Reddave For This Useful Post:
    MB (19th February 2019), PeeBee (18th February 2019), Touses (19th February 2019)
  8. #84
    Dec 2012
    Work
    Started boxing up next to my fridge to make full use of the drivers Emuwing, then I’ll work out what I’ll be doing with the passenger side
    Also trying to find a way to quieten the cab noise, got a decibel meter app on my phone and am getting 70db inside the cab at idle, 85db at 2,500rpm.
    Sounds cool but makes my ears ring after a couple of hours.
    I have a few new covers coming for the gearsticks, but still might have to pull the carpet up and put some dynamat/underlay in
  9. The Following User Says Thank You to Reddave For This Useful Post:
    MB (25th February 2019)
  10. #85
    Dec 2012
    Work
    Got my high mount top hat finished, Freespool eliminator, Gigglepin brass bushes, painted flat black
    Then started on my sound deadening, this is stage 1, butyl based. Then I put a second layer on which is a closed cell foam with a rubber mat glued to it, got my interior back together today and found I had a flat battery
    Battery’s on charge now, so can’t drive it and compare before and after, results tomorrow hopefully
  11. The Following 3 Users Say Thank You to Reddave For This Useful Post:
    0-TJ-0 (12th May 2019), MB (18th May 2019), Rossco (12th May 2019)
  12. #86
    Dec 2012
    Work
    Went for a drive when I got home from work, drove down the freeway and dropped 3db
    Idles better as well, down 4db
    Car is so much better now, I’ll be attacking the doors and possibly the roof, trying to get it under 80 dB
  13. The Following 2 Users Say Thank You to Reddave For This Useful Post:
    MB (18th May 2019), mudnut (13th May 2019)
  14. #87
    Dec 2012
    Work
    My headlights have been playing up, I assumed it was just the eBay cheapies so bought a set of ADR approved Narva LEDs.
    Fitted the new ones and had the same issue, had 8 volts at the R/h headlight, turns out it was the headlight switch ��
    Replaced that and tested, all works now
    Then replaced all my bailey channel rubbers and weather strips, hopefully get this thing dirty in a week or so, I’m nearly prepped and ready for Queens birthday weekend
  15. The Following User Says Thank You to Reddave For This Useful Post:
    MB (18th May 2019)
  16. #88
    Dec 2012
    Work
    Went out on Sunday to Wombat state forest
    Love this car!!
  17. The Following 2 Users Say Thank You to Reddave For This Useful Post:
    MB (21st May 2019), Rossco (20th May 2019)
  18. #89
    Quote Originally Posted by Reddave View Post
    The GQ didn't run headlight relays. Fitting them was one of the best mods I have done. The switch should now last the life of the vehicle.
  19. The Following User Says Thank You to mudnut For This Useful Post:
    Reddave (20th May 2019)
  20. #90
    Dec 2012
    Work
    https://www.youtube.com/watch?v=4YJT...&feature=share
    Idiot me forgot to actually put it in 4wd
    https://youtu.be/ailEzMPB4SI
    Once I put it in 4wd walked straight over
    (Pardon the amazing video skills, someone held the phone the wrong way)
    https://youtu.be/b3JyumdR5ao
    If someone could help with embedding videos that would be awesome!!
  21. The Following 2 Users Say Thank You to Reddave For This Useful Post:
    jay see (26th May 2019), MB (21st May 2019)
