Page 4 of 18 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 172
Thread: Back in a GQ
  1. #31
    Dec 2012
    Work
    Removed my dump pipe last week after buying gauges so I could weld in a bung for my EGT, broke every stud on the turbo
    Got all of them out but one, so had to remove the whole lot to get it out, got there in the end though
    Then had to wait till today for eBay to deliver my gauge pods so I could fit the gauges
    Fitted a battery in the back, excuse the ratchet strap holding it in and the loose wiring was just to work out if what I was trying to achieve would actually work, I still need to run cabling from the battery under the bonnet and fit my isolater
    Just another Blue over Silver GQ with another TD conversion
  2. The Following 2 Users Say Thank You to Reddave For This Useful Post:
    MB (19th September 2018), Rossco (18th September 2018)
    Dec 2012
    Work
    GU diff is in, 4.6s and lockers are in, heavy duty steering arms in, 315/75 16 Procomp muddies on, took it for a drive and then death wobbles
    New panhard bushes and steering damper fixed it, just about ready for a shakedown run over the Vic long weekend
  5. The Following 2 Users Say Thank You to Reddave For This Useful Post:
    MB (26th September 2018), MB TD42 (1st October 2018)
  6. #33
    472 Post(s)
    Should climb tops Dave mate, awesome!
    IMO tis a bad long Vic weekend for a run, boys in blue galore already ramping up!
  7. #34
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    4.6ers...5th gear all day... looking to install GU running gear on mine...did you go wider or just the diff center swap?
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
  8. #35
    Dec 2012
    Work
    Took my two youngest sons away for a quick overnighter Saturday arvo, car was faultless, slowly dialing it in.
    Had coppers come through Saturday night, just making there presence known, no hassles
    Quote Originally Posted by MB TD42 View Post
    Replaced the whole GU diff assembly in the front, just replaced the rear centre, makes the car heaps better to drive, 4.6 and 35s are spot on to stock and as a bonus speedos now accurate!!
  9. The Following 3 Users Say Thank You to Reddave For This Useful Post:
    AB (2nd October 2018), MB (2nd October 2018), MB TD42 (3rd October 2018)
  10. #36
    Dec 2012
    Work
    Bought a jerry can holder off a Jayco and mounted it up to the little barn door, just saved myself $2500 by not having to put swingaways on!!
  11. #37
    Quote Originally Posted by Reddave View Post
    Where do you put your number plate now mate? I had issues with finding a good spot for mine when I fitted my rear bar
  12. #38
    Dec 2012
    Work
    I will put it at the bottom, when I fit it up I’ll post a pic, next weekends job!
  13. The Following User Says Thank You to Reddave For This Useful Post:
    rusty_nail (9th October 2018)
  14. #39
    194 Post(s)
    That tyre looks massive. Is it on a wheel carrier or off the rear door? I had trouble with door hinges on mine from brand spanking new, couldn't keep the door closed after corrugations, and they were factory baby 31x10R15!
  15. #40
    Dec 2012
    Work
    Yea, it’s huge, off the rear door for now, but looking at a more creative way to mount it
  16. The Following User Says Thank You to Reddave For This Useful Post:
    PeeBee (8th October 2018)
