13th January 2018, 10:44 AM
Zd30 lack of power
Hey fellas,
Recently bought a 2000 zd30 gu, and its a bloody slug.
Maxs out on a flat road at about 110, flat to the floor. Going up hills slows back down to 70-80 on the highway.
When i first got it home, was having a look and there was no air filter, so purchased one, and cleaned the maf, but its still bloody gutless.
Sometimes itll boost to about 16-18psi, others it wont go over 5 until you restart the car.
Just wondering what you fellas would suggest doing, cheers.
13th January 2018 10:44 AM
13th January 2018, 11:15 AM
Start by trying another maf sensor that's known to be good ,replace fuel filter is where I'd start .
13th January 2018, 11:27 AM
Sounds like limp mode ..... disconnect the battery for 30 min to clear any codes and try again.
I would install a new MAF, as who knows what has been going on with no air filter
13th January 2018, 11:42 AM
Missing in Action
Sounds like it is in "Limp Mode". Mine was doing the same thing, no guts over 2500 RPM. Mine was caused by a faulty wire to the MAF sensor. The wire was damaged weeks earlier when a fan belt failed damaging the wires under the air intake, might be worth taking a look at them. If wires are OK then it is probably the sensor itself.
13th January 2018, 12:00 PM
jschw99
Hey fellas,
Does the engine have manual boost control fitted (Dawes-Tillix / Needle)?
Any other mods to engine that you can see apart from running air filter delete.
The motor sounds like it has been neglected so first do your oil/fuel filters and change your oil out (if not yet done).
13th January 2018, 06:19 PM
Already done the oil & filter. Just waiting until next week before i can do the fuel filter. Will try disconnecting the battery and see how i go there.
Also, which wires on the maf am i to check? On the connection that plugs into maf? Sorry, completely unexperienced in zd30s
14th January 2018, 02:06 PM
Alright, tried disconnecting the battery for a while and still gutless.
14th January 2018, 02:35 PM
#8
I am he, fear me
15th January 2018, 08:51 PM
#9
Hey boys, took into a mechanic today. Fault code was regarding the maf sensor, and apparently it was just not working at all. Got a new one im putting in in the morning, and they mentioned something about remapping the ecu. How do i go about that?
15th January 2018, 10:05 PM
#10
I am he, fear me
jschw99
Disconnect the battery for 30 minutes.
That forces the ECU to relearn its parameters for the factory map.
If you want a different map entirely then that means hooking up a PC or changing chips which means forking out $'s
