Results 1 to 10 of 12
Thread: Installing factory dash clock in GQ 1997
    194 Post(s)
    Guys,
    I bought a factory clock from the wreckers to install in my vehicle. Whats the process to get the lower dash apart to gain access behind the facia?
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Geez it's been that long since I last removed mine and I've done it about a half dozen times or more I'd have to take a look at mine again but from memory two screws at the top and two at the bottom .cant remember if there was one to get after removing ash tray .
    If no one answers Phil I'll look at mine in the morning .
  4. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    PeeBee (15th April 2018), Rossco (15th April 2018)
    193 Post(s)
    Easy as in the GQ. Two screws in top of each vent, two screws either side and one behind the ashtray, think that's all. .
  6. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    GQtdauto (16th April 2018), PeeBee (15th April 2018)
  7. #4
    Yep that's it, and be careful you don't pull any wires off the back of any of your aftermarket switches as you pull the fascia off.
  8. The Following User Says Thank You to Winnie For This Useful Post:
  9. #5
    194 Post(s)
    Thanks Guys, will have a crack at it later this week after work. I am sure to make a meal of it and it take 3 nights to get the thing back together. I also am hoping the plug is there waiting to connect to. I have not had a look yet but hope these screws have hex heads - dont like my chances of getting a crab claw and screwdriver into the ash tray area! What about the single screws on each side, passenger and drivers - do they need to come out as well?
  10. #6
    194 Post(s)
    OK, 4 screws in the vents, one screw on l/h side of ashtray and one to rear of ashtray - looks like its accessed via removing the rear demister switch - any more, sound about right?
  11. #7
    Rear demister is up near the lhs stalk?
    Pull the ash tray out and the screw is behind that.
    The screws are all Philips head, use a magnetic screwdriver
  12. The Following User Says Thank You to Winnie For This Useful Post:
    PeeBee (16th April 2018)
  13. #8
    193 Post(s)
    Yeah two screws per side come out. They're all Phillips head ash tray one is easy, it's not too deep. .
  14. The Following User Says Thank You to Rossco For This Useful Post:
  15. #9
    194 Post(s)
    OK, thanks guys, all done. Getting the screws back into the rear of the clock was a pain due to the cable loom being in the way, but a few choice words and it was done. Was hoping it would actually be 'on' all the time so you could see the time at a glance, but needs the ignition source - not going to stuff with it now, simply get used to it.
  16. The Following User Says Thank You to PeeBee For This Useful Post:
    GQtdauto (15th April 2018)
  17. #10
    @PeeBee I have a triple gauge binnicle on top of my dash brought a 12v clock didnt like it
    Brought a $27 52mm quartz clock and love it perfect fit, takes a L44 battery easy as
