Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Best way to remove dent on fold rear quarter
    581 Post(s)
    So I had a little mishap on the weekend with a hidden branch behind a bush on a very tight overgrown seldom used track.
    I'm going to have a crack of trying to get the rear quarter dent out on the fold of the panel.
    What would be the best way to tackle this?
    Heat the guard to try and stop paint cracking, go in from the jack holder compartment with a plate on bottom of fold and hit out and repeat on high side of fold?
    Any help appreciated folks!!
    Not after perfection...
    22 Post(s)
    I dont think you'll get away without damaging the paint, because it is creased imo. But I'm hopeless at body work
    96 GQ coil/Cab
    08 G6eT
  4. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    AB (13th April 2018)
    581 Post(s)
    Mate I have zero idea on what I am doing lol
    22 Post(s)
    Go get a plenishing hammer and start hitting stuff
    96 GQ coil/Cab
    08 G6eT
    330 Post(s)
    Bring it here
    330 Post(s)
    Thats a 2 person dent
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    PeeBee (13th April 2018)
  10. #7
    109 Post(s)
    When Peter Tommasini had his show on Ch31 I was transfixed every episode. Do some googling under his name you might find something. Absolute metal genius.
  11. The Following User Says Thank You to Plasnart For This Useful Post:
  12. #8
    .......... TPC's Avatar
    63 Post(s)
    Would you worry about removing a dent from a GQ?
  13. The Following 2 Users Say Thank You to TPC For This Useful Post:
    AB (13th April 2018), GQtdauto (14th April 2018)
  14. #9
    Jan 2018
    Pt Augusta SA
    enough blasphemy from you sir begone!
  15. The Following 3 Users Say Thank You to Pete49 For This Useful Post:
    AB (14th April 2018), MudRunnerTD (14th April 2018), Rossco (14th April 2018)
  16. #10
    Legendary happygu's Avatar
    That dent is not coming out without paint damage.
    Removing the inner trim will give you access to get in there, but since the fold/crease line is damaged, it will take a lot of beating, and pulling to get it straight again. To get it straight properly, the paint needs to be taken back to bare metal.....
  17. The Following User Says Thank You to happygu For This Useful Post:
