Results 11 to 20 of 27
Thread: Powerful 4x4 rear wheel carrier / bar
    Make your own tube bar or something?
    Yeah I thought about that. But I’d have then make a tube front bar so it would match, then my Patrol would just be more cop bait and down here we don’t need anymore of that. I’d love to be able to have the skills to make my own bar. The ones on the market now I reckon have too much weight on them.
    22 Post(s)
    One thing I have learnt from helping a mate build barwork over the last few years at his shop, is that many of the same brand, year etc are different. To get it right every time barwork has to be built on the vehicle. It's surprising as the differences are bugger all. But, it is the difference between fitting nicely, poorly or not at all.
    96 GQ coil/Cab
    08 G6eT
  4. #13
    22 Post(s)
    You can make a tube bar with sheet metal inserts to fill in the gaps. It's only for aesthetics so it can be light and if it is well thought out it can be very subtle
    96 GQ coil/Cab
    08 G6eT
  5. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    mudski (13th April 2018)
  6. #14
    175 Post(s)
    @mudski
    Remember me and you compared rear bars at last year's show ? We looked at the powerful one. And a bunch of others.
    From memory steel thickness, and the way it was powder coated , didn't appear to be too good.
    Also im not an expert welder , but the welds appeared very ordinary in contrast to others ...
    However , others were fair bit more $$$.
    Having 3-4 different brand under same roof , to compare them just about side by side, was enough to tell where you're spending the extra $.
    I'm looking at the Kaymar Ozbar personally.
  7. The Following User Says Thank You to Hodge For This Useful Post:
  8. #15
    Nov 2010
    Getting a life...
    38 Post(s)
    What aren't you happy with?
    It doesn't line up properly, when I rang them about it they said 'just force it over'. Bit hard when the braces are hard against the chassis. The Jerry can holder welds have broken several times, hubby's reinforced it, which has added extra weight. It also vibrates loose constantly, so I leave it off. The whole Bar vibrates like a bastard and I had to make my own nut to hold on spare wheel. Close the spare wheel and it moves the whole Bar. Id save longer and get better quality.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  9. #16
    192 Post(s)
    Yeah I'd be x2 on Millweld or Racebred can't fault either of their stuff and very reasonably priced. . .
  10. #17
    .......... TPC's Avatar
    63 Post(s)
    I will have to wait for someone to run up the back of mine so I can get insurance to help pay for a decent bar.
    Had considered the Powerful 4x4 but changed my mind after reading this thread.
  11. The Following User Says Thank You to TPC For This Useful Post:
    katwoman (13th April 2018)
  12. #18
    @mudski
    Yeah thats right....
    The only thing i didnt like about the Ozbar is I have to use my existing tow bar. its not a deal breaker but...
  13. #19
    Yeah I'd love to Ben. I have thought over this many times. It keeps getting thrown into the too hard basket though.
    Those Milweld bars do look nice though. Hopefully they come up with a design for the self opener on the large door. I do like that...
  14. #20
    49 Post(s)
    Guy has a bullbar on his new lux and it's always coming loose. They have a welded eyelet that they say is a rated recovery point. I don't know much about them, but enough not to buy from them
