Results 1 to 10 of 13
Thread: Long Range Tanks
    May 2016
    lower west victoria
    30 Post(s)
    Long Range Tanks
    I'm looking at some long range tanks for the GU.
    Wondering if anyone has fitted/used/knows about the Brown Davis NPGUA2 tank? It replaces the sub tank.
    They say it holds 80 litres. But I'm wondering if it can hold 80, or can you only ever get less than 80 into it, like the standard Patrol tanks??????
    Thanks.
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Thanks.
    Hey mate, not sure on the sub but I had a BD main tank and it would take full capacity.
    I can definitely say they are tough, mine took a fair few knocks and no dramas what so ever.
    ________________________
    ______ 2017 D-Max _______
    462 Post(s)
    I have a long range sub tank. Bought it second hand from a member, @boots, where are ya mate!? Anyhow, I can get around 80 ltrs in mine. Usually around 75ish now when the gauge reads empty.
    As for brand, not sure what it is. I fitted it, and it works. I just had to cut and lengthen the arm on the tank sender float from the original tank...
    Nov 2010
    Getting a life...
    38 Post(s)
    My GU has the 80L Bd sub tank and as far as I know it takes the full 80L. Not 100% on that as I never let it get empty. But never had any probs with it. If I was to do it again I'd go the 90L.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
    May 2016
    lower west victoria
    30 Post(s)
    Hi Katwoman.
    That's good to know that I should be able to get 80L into it. The 90L tank requires a body lift, which I don't have.
    I was thinking of doing the main tank mod as well to increase that, @bigguwesty says he can get about 105L into his main tank after doing that mod.
    I really ran my main tank down one day, as far as I felt safe to and I got 86L into it when I filled it up so I'm hoping @bigguwesty got 105L in at the bowser and not filling it when it was out of the car our something.
  7. The Following User Says Thank You to 10G For This Useful Post:
    katwoman (13th April 2018)
    Expert Ibbo's Avatar
    Mt Barker, SA
    Hi Katwoman.
    What is the main tank mod you refer too? Tried searching on forum but could not find anything. Heading across the Simpson in July and need all the fuel storage I can get! Thanks.
    Sent from my Moto G (4) using Tapatalk
    2010 GU, 2in lift, old man emu suspension, duellers, arb bullbar, dual batteries, safari snorkel, scangauge2, rhino rack platform, saving for more......
    Raising the breather allows for more fuel as it leaves less space for expansion
    http://www.nissanpatrol.com.au/forum...+tank+breather
  10. The Following User Says Thank You to the evil twin For This Useful Post:
    Ibbo (13th April 2018)
  11. #8
    49 Post(s)
    I can't remember if I've got a brown Davis or a lra, but it's a 80l sub tank and yeah I get the full amount in.
  12. #9
    WA Wheatbelt
    23 Post(s)
    My ute's got a 90lt mains and either 75 or 80 reserve.
  13. #10
    How's the serenity boots's Avatar
    Sep 2011
    Hello mate how you been , long time since I snooped around here, too long, hope your well Mark.
  14. The Following User Says Thank You to boots For This Useful Post:
    mudski (28th April 2018)
