Results 1 to 10 of 16
Thread: What is that noise??
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    Hi all
    I have a 1994 TD42 coil cab, and since I bought it I have noticed a noise that I can describe as a chatter or rattle. It only happens at low revs under load, and when engine braking down a hill. When driving through the sand at low revs it constantly makes the noise. Would you be able to tell me what it is so I can get it fixed, as it makes the car sound very unhealthy.
    Td42 coily
    Jan 2018
    Low revs and/or under load creates a lot of vibrations .
    If its rattles and clacky then check all your heat shields.
    Sometimes engine mounts wear out so makes these rattles worse as opposed to a new engine mount that doesn't allow these rattles to occur.
  4. The Following User Says Thank You to drgtr For This Useful Post:
    JackoGQYoot (4th April 2018)
    Oct 2017
    WA
    Could it be the clutch at all? How much would a new set of engine mounts cost me?
    Td42 coily
    I thought all 4.2s made a weird sound down low ask @Winnie
  8. #5
    Oct 2017
    WA
    Yeah, I read on another forum, it may be the springs or something inside the clutch, and a few guys have got rid of the noise by changing their clutch to heavy duty and replacing the gear oils.
    Td42 coily
  9. #6
    Patrol Guru
    May 2011
    mackay former alice boy
    If it sounds like its coming from the gearbox and changes pitch with a give or take 50rpm its the 4.2 torque rattle and that's to let you know the big tractor is working down low.
  10. The Following User Says Thank You to dads tractor For This Useful Post:
  11. #7
    Oct 2017
    WA
    Would the toyota 4.2 diesels make the same noise? I heard an 80 series non turbo drive past and it made that same noise.
    Td42 coily
  12. #8
    Oct 2017
    WA
    Hi guys
    I am looking at replacing the engine mounts on my patrol, which may have something to do with the noise. What does it take to replace them? I am looking at the Superior engineering comp spec ones. Is there any welding or anything to do, or can I fit a new set in my driveway? How many of them are there to replace?
    Td42 coily
  13. #9
    192 Post(s)
    Hey mate just be aware the superior ones transmit A LOT of vibration through to the car @Winnie has some in his GQ. From experience the factory ones seem to be fine.
  14. The Following 3 Users Say Thank You to Rossco For This Useful Post:
    Bidja (4th April 2018), JackoGQYoot (4th April 2018), Winnie (4th April 2018)
  15. #10
    201 Post(s)
    Quote Originally Posted by JackoGQYoot View Post
    Hi guys
    There are two mounts to replace, it's tricky but can be done in the driveway. I have the superior mounts and don't like them, they vibrate a lot at low revs and make it impossible to hold a conversation.
    I'm looking at swapping them out again with genuine Nissan mounts.
  16. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    JackoGQYoot (4th April 2018), threedogs (4th April 2018)
