Results 1 to 10 of 19
Thread: New tyres help
    Mar 2018
    New tyres help
    Didn't find a thread so I made this one
    Part of our job is to visit local farmers
    So we need to go off-road sometimes
    Problem is my tyres can't endure the environment (last time I did 23 patches in just two days and two tyres were in unrepairable)
    Stock tyre size 265/70R16
    Environment is filled withy spicky bushes and dry hard stems (puncture resistance required)(no way around it)
    Sometimes muddy
    So what type and size of tyres should I get
    And do I need to change my wheel size
    Any help is appreciated
  2. The Following User Says Thank You to pro25ahmed For This Useful Post:
    Salim (27th November 2018)
    472 Post(s)
    New tyres help
    G’day Ahmed mate!
    In Australian Southern rocky conditions I’ve relied on BF Goodrich Mud Terrain KM1’s & KM2’s for well over 10 years now.
    The beautiful African environment you describe above sounds very tough my friend.
    I have never used them but I believe there is a system that USA Baja desert racers and their rock crawling drivers use with a secondary inner tough tube thing. Others here will know what they’re called but possibly could work for your needs maybe?
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    Are they called internal beadlocks? There are good ones for most rim sizes on Snake Racing: http://shop.snakeracing.com.au/secon...-x-10-12-wide/
    I think these just allow you to run lower pressures than you'd normally be able to. I've heard of people running their tyres at 4psi with these!
    Td42 coily
  6. The Following User Says Thank You to JackoGQYoot For This Useful Post:
    MB (30th March 2018)
  7. #4
    ya need a 10 ply side wall not 3ply..look for a lt-light truck
    mate did heaps of driving through saltbush n stick out of kalgoolie..swore by 10 ply sidewall...hope that helps mate,
  8. The Following User Says Thank You to Avo For This Useful Post:
  9. #5
  10. #6
    472 Post(s)
    Cheers Jack, I think that’s them mate. I guess my theory was to let those nasty described prickles pass through a tyre but not the tough inner one you helped on here, could work hopefully?
  11. #7
    472 Post(s)
    Apologies, typing same time as Avo mate. West Australians Ahmed mate know your similar turf for sure!!
  12. #8
    nah the internal Bead locks are designed specifically to hold the bead and are quite small. They will not stop teh tyre going down if it is puncture but will stop it popping a bead.
    For my money i would look at something with big side wall lugs to protect from impact and puncture by thickness alone.
    Choice number 1 would be Simex Jungle Trekker2. Great tough tyre. Military spec. Rain Forrest Challenge winner and just tough. They also come in smaller sizes so will work in a 33, 34" tyre if that i what your chasing. Will be great in the wet seasons too.
    http://www.dynamictyres.com.au/our-tyres/simex
    Choice 2 Wrangler MTR have a Kevlar reinforced side wall and a good quality but Dear as Poison.
    http://www.goodyear.com.au/dotCMS/Ty...de=00782&from=...
    Choice 3 would be Maxxis Treps. Tough big side walls but start in 35s and go up.
    http://www.maxxis.com/catalog/tire-4...trepador-m8060
    Hope that helps.
  13. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  14. #9
    Mar 2018
    Thanks everyone
    I checked with local dealers
    But they only have high way rated
    Gonna try down town later
    Thanks again
  15. #10
    Jan 2018
    Im running Khumo Kl71 Mud terrains.
    I love them
    https://www.youtube.com/watch?v=fu93bDq6pR0
