Results 1 to 9 of 9
Thread: Rollstarting
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    Rollstarting
    Hi all
    I was just wondering, if someone tried to steal a mechanical diesel, manual vehicle, would they possibly be able to roll-start it without using the key? Or do they need the key to keep fuel coming?
    Cheers.
    Td42 coily
    193 Post(s)
    Fuel cut solenoid needs power to it. Some old injector pumps have an external solenoid with a lever that you could probably push by hand.
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    done it with the key. still had 8 volts in the battery took 3 ppl. but if you know your way around the engine bay and have some wire yes you could. you would still need to remove the steering lock.
    but you could of just hot wired it, be easier
    Oct 2017
    WA
    Cheers guys that has settled a few worries!
    Td42 coily
    Quote Originally Posted by JackoGQYoot View Post
    there's a bit of info about kill switches here to Jacko...all good info matey
    is byford the new armahole
  8. The Following User Says Thank You to Avo For This Useful Post:
    Clunk (30th March 2018)
    Get yourself a good immobiliser
    And msybe a kill switch...... It isnt that hard to remove an ignition barrel and start it with a screw driver
  10. #8
    and he ain't even with the mob
  11. #9
    473 Post(s)
    Shame they’ve banned them now :-( https://youtu.be/w39o6eSI06Y
  12. The Following 2 Users Say Thank You to MB For This Useful Post:
    Avo (30th March 2018), Clunk (30th March 2018)
