Results 21 to 30 of 33
Thread: Oil Leak Turbo Oil return Line
    Jan 2018
    581 Post(s)
    Nah you don't need to spend that much on a full kit. You just need a straight flange and get hose and clamps from local autobarn, supacrap or repco.
    I would personally get a straight flange and it just needs to suit a 51mm bolt spacing.
    Something like this but have a search on EBay and maybe measure the vertical distance from turbo to block drain to make sure there's enough distance for the hose to do a nice even curve to your block for smooth drain and minimise sharp 90 degree turn of pipe so it doesn't kink if that makes sense.
    https://m.ebay.com.au/itm/Turbo-Oil-...-/301682866510
  4. The Following User Says Thank You to AB For This Useful Post:
    drgtr (28th March 2018)
  5. #23
    581 Post(s)
    Barb style oil drain flange.
  6. The Following User Says Thank You to AB For This Useful Post:
  7. #24
    Jan 2018
    You are too awesome.
    Thankyou.
    I ordered this. My mate needs a feed line. I need the drain line.
    https://www.ebay.com.au/itm/MAMBA-Tu...UAAOSw0hRZcZBz
  8. #25
    581 Post(s)
    Awesome that'll do. Make sure your mate pays $100 and you pay $22 lol
  9. #26
    May 2016
    8 Post(s)
    Not to much crankcase pressure it's not breathing a bit hard ? Blocked engine breather
  10. The Following User Says Thank You to Tip12345 For This Useful Post:
    AB (28th March 2018)
  11. #27
    581 Post(s)
    Yeah my thoughts too Tip...
  12. #28
    Jan 2018
    Quote Originally Posted by Tip12345 View Post
    Sorry i dont understand. Where is the engine breather? It has an oil catch can. Not much blow by.
  13. #29
    Jan 2018
    Is it that round thing at the back of the rocker cover.
    How do i clean or unblock it
  14. #30
    May 2016
    8 Post(s)
    Just remove the oil cap when running and see now much pressure its blowing out
