Results 1 to 4 of 4
Thread: Door Autolocking GU Tip
    Jan 2018
    Now I know The Patrol is programmed to autolock the doors if you press unlock on the remote or unlock via keys but you dont open the doors in 30 seconds.
    Now this leads to a common problem.
    Alot of owners dont have the interior lights on so you dont realise when your door switch starts to play up
    and when the door switch goes faulty or intermittently faulty you have a good chance of locking your keys inside.
    almost happened to me today.
    Basically the door switch thinks you havent open the door yet when in fact you have.
    I went to open the bonnet. 20 seconds later I hear the door locked.
    I thought it was odd.
    then i remembered door switch on drivers side is intermittently playing up because of the interior lights flickering.
    So yes replace your door switch guys. 20 dollars later and all good again.
  2. The Following 3 Users Say Thank You to drgtr For This Useful Post:
    altech (27th March 2018), GQtdauto (26th March 2018), Yeti's Beast (27th March 2018)
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Yep mine did that also, lucky I still had the keys in my pocket
    461 Post(s)
    That auto lock function must be on the newer Y61's. My GUII doesn't auto lock....
    Jan 2018
    Probably GU3 onwards then. Interesting.
