Results 1 to 8 of 8
Thread: What EGT temperature rang should I be in ?
    Expert First Pooy's Avatar
    Mar 2018
    I just installed a EGT in my Td42 Gq what temperature rang should I be in or keep away from?
    472 Post(s)
    G’day mate, consesus I believe kindly read on here too prior to fitting one ourselves on the TD42T family truckster was 550D+ (extended periods) was danger zone. We chose a Redarc twin jobbie for boost as well and had the EGT audible alarms set for 550 alert then 600 squealing at us. An intercooler and new tune would keep ours happier but unsure if you can do too much about exhaust temps on a TD42 naturally aspirated, others will know best mate but they are pretty tough donks we’ve foolishly torture tested :-) !
    581 Post(s)
    Is it intercooled mate?
    Mar 2018
    No it is not intercooled and running 11 psi
    Mar 2018
    I am climbing a reasonable hill my foot flate to the floor in 5th doing about 90 km I am purposely loading it up the temperature gauge just over half way and the EGT is saying the exhaust temperature is 29 degrees,interesting?
    Quote Originally Posted by First Pooy View Post
    That will be the cold junction temperature.
    IE the gauge can't see the thermocouple because you have a wiring fault/short/wrong connection
    It is best to put the thermocouple pre turbo somewhere in the collector area before entering the turbo.
    Mar 2018
    Interesting point but I have no excess to the collector area with out drilling and taping a thread
