24th March 2018, 07:24 PM
#11
It does, but I don't know what the other guy has and is it was in convoy, but sometimes working and sometimes not.
Haven't got around to looking into this yet, maybe after dinner.
Thanks.
24th March 2018 07:24 PM
24th March 2018, 07:34 PM
#12
Had trouble with mine and first fault found was plug at the back where aerial screws in was loose , then found cable pinched by spare battery holder and at the moment it turns on when it wants to but have hand held just in case .
The Following User Says Thank You to GQtdauto For This Useful Post:
jay see (24th March 2018)
24th March 2018, 07:48 PM
#13
GQtdauto
Had trouble with mine and first fault found was plug at the back where aerial screws in was loose.
Funny that.
I just checked and they were both loose. Tighten up and checked with the handheld so far working as it should.
Thanks again gents...
The Following User Says Thank You to jay see For This Useful Post:
24th March 2018, 07:56 PM
#14
Tighten then up with a spanner, maybe a small dob of loctite 232 on the smaller cable fitting into the larger fitting.
25th March 2018, 12:06 AM
#15
Patrol Guru
Was reading this & saying to myself "I bet the small nut that screws the coax into the plug is loose" & sure enough I get to the end & there it is . So many new trucks these days have the exact same problem & so far I've had a 100% success rate with the diagnosis each time .
The Following User Says Thank You to Sprock For This Useful Post:
jay see (25th March 2018)
25th March 2018, 12:17 AM
#16
Sprock
Well picked Sprock. Would have been more helpful a few hours earlier.
Only stirring you up mate. I know you can handle it.
26th March 2018, 02:59 PM
#17
Patrol Guru
Haha go your hardest mate , when I dish out as much shit as I do I need to have a thick skin for return fire 😏
26th March 2018, 05:51 PM
#18
Run an earth from under the antenna to the earth of your battery,
its not always your unit causing problems.
