Results 1 to 10 of 12
Thread: No power at all
    Sep 2017
    Nowra
    No power at all
    I’ve just installed a new alternator, before starting the install I removed earth strap off the battery, I installed alternator and went to put earth back on battery and it sparked the the positive side had some smoke,
    Now I have no power at all.. I’ve been through all fuses and found a 10amp from under dash blown so I replaced it. It was for eng cont
    It’s a td42 converted using all Tb42e wiring, there is one wire that goes to the battery that controls everything power wise but I don’t know where to look for fuse or relay that’s directly to that wire.. if anyone can help me shed some light on what happened that would be great! I’m going a little bonkers 😅
    194 Post(s)
    I think there are a couple of man fuse blocks in the small enclosed fuse box under the bonnet - on drivers side - next to guard - you need to unscrew the op panel to access - they look like relays boxes from memory. By some chance you didn't hook up the pos and neg battery cables in reverse on the alternator? Sounds like a main fusable link also? Can't recall where that is though.
    Sep 2017
    Nowra
    nah mate I only removed negative from battery and I don't believe I did as far as alternator I just copied how it was already installed but I will have a look over incase I have mucked something up, also I have looked at those relays but everything looks fine? I'm not really sure what to do from here...
    194 Post(s)
    OK< there re also some big fuses in there as well, brown ones, green ones and white I seem to recall. One of those actually drops off all power to the vehicle - I think @AB might even remove his on occasion as an anti theft deterrent? I know the car wont run if its blown, or at least thats what happened on my GQ 2.8 once when I shorted out a cable. If the blue topped relays are damaged they would probably have signs of melting on the top covers, but sounds like they are ok.
    Sep 2017
    Nowra
    yep I've checked them also and all is fine I'm really confused on whats happening... do the tb42e have a body control system? maybe I've burnt that out? I'm just so confused on how it even happened when all I did was remove neg cable from neg battery post swap alternators then put neg strap back to neg post...
    194 Post(s)
    Nope, I am out on this one now, sorry.
    The fusible links are near the positive battery post. They have plastic connectors on each end.
  9. The Following User Says Thank You to mudnut For This Useful Post:
    PeeBee (22nd March 2018)
  10. #8
    Sep 2017
    Nowra
    checked all them too mate all A OK, I'm so stumped..
  11. #9
    Sep 2017
    Nowra
    Quote Originally Posted by BrodieTiGQ View Post
    This is the main power , where’s the fuse or relay for this?
  12. #10
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    In mine there under a cover just to the right of your hand and just below where you have your hand , because it's been converted it's all different .
    But if when you touched the leads the dreaded smoke came out something's amiss with the way you hooked the alternator up or possibly something was left on .
