Results 1 to 4 of 4
Thread: factory diff lock VS shimmed LSD
    Sep 2017
    Nowra
    So I have a GQ TI and have a factory rear diff lock , the diff lock doesn't work and I haven't looked into it (probably something simple) but anyways, the gear ratio is 3.9 and I have another set of diffs (4.11 ratio) with the rear LSD which I have shimmed with a 0.55 shim
    My question is which is the better option? should I keep with the factory locker and sort out why its not working or swap it out for the limited slip?
    im intrested to hear your thoughts!!!!
    post edit:
    I should probably add its a td42 turbo manual 33's
    330 Post(s)
    Swap out for the better ratio and the LSD is great in the Patrol. Go the front locker while you swap out.
    X 2 ^^^^
    Sep 2017
    Nowra
    yep thats what I've been told , I was also thinking that having the LSD will be better for towing also
