9th April 2018, 08:44 PM
#21
CORE SIZE:
630mm(H) X 570mm(W) X 32m(T) 1 ROW
The Following User Says Thank You to drgtr For This Useful Post:
dpetersen (9th April 2018)
9th April 2018 08:44 PM
9th April 2018, 08:45 PM
#22
9th April 2018, 09:25 PM
#23
drgtr
Thanks @drgtr. Looks like the adrad it the go!
2006 4.2 tdi wagon
Plenty more to come!
27th April 2018, 01:37 PM
#24
I have aftermarket VDO temp gauge and now have sorted the problem of large movements up and down(60 to 115) because cable from sender was lying on top cable for EGT for some distance to rear of dash and obviously stray current was causing problems.Glad I installed Dessert Cooler radiator before last trip to the West.
Not impressed with VDO Aust distributor as they do not answer phone or return calls when a message is left.
18th June 2019, 10:38 AM
#25
dpetersen
Thanks @
How did you go in the end? All worked out?
18th June 2019, 11:11 AM
#26
drgtr
Changed the rad with the adrad. It was sitting on around 90* at 100k p/h with temps about 45 outside. If I pushed it any harder to say 110, temps got to around 108*.
Iv fitted a 3inch exhaust since then though with dump pipe, new injectors and a tune plus a rebuilt fuel pump. Hasn’t really been hot enough since though to test it out though so will have to wait until summer now.
2006 4.2 tdi wagon
The Following User Says Thank You to dpetersen For This Useful Post:
18th June 2019, 07:24 PM
#27
Where do you have the temp sensor again?
18th June 2019, 07:28 PM
#28
dpetersen
Also advance your timing too. It will go sooo much nicer and lower EGT too
dpetersen (18th June 2019)
