Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Front Hub lock and 4wd questions
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    As ET has already posted, tyre pressures are critical on sand. I prefer 15-18 psi for normal sand.
    I have had the tyres down to 10 psi to get up dunes where there is soft sand or no run up area at the bottom.
    The trick is not to turn too sharply at those lower pressure, or you might roll the tyres off the rim. Don't be put off experimenting with tyre pressures to suit your vehicle, tyres and terrain.
    With the correct pressure, the vehicle should roll to a stop, not dig in or bog down. This will ensure you are not putting too much stress on the drive train and engine too.
    Jan 2018
    2 Post(s)
    The trick is not to turn too sharply at those lower pressure, or you might roll the tyres off the rim. Don't be putt off experimenting with tyre pressures to suit your vehicle, tyres and terrain.
    Stress on the engine is the last thing I want on a 40 degree day on the hot sand with a td42ti lol.
    I wonder what my coolant temps will be like on the sand .
    Though at stockton beach on hot 38 degree day and soft sand. My newish v6 prado 120 was sitting on 99 degrees c too
  4. #13
    SW Vic.
    80 Post(s)
    A TD 42 will romp it in, if the cooling system is in good nick. Take it out locally, perfect your technique and check it if you are at all concerned.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    drgtr (16th March 2018)
  6. #14
    Jan 2018
    2 Post(s)
    Yeah. Thats what I want to hear!
  7. #15
    Legendary happygu's Avatar
    2 Post(s)
    I rarely ever take mine out of 4wd when I am on the sand, as you never know what is around the corner and you are much better off not getting stuck. The real question is High Range 4wd or Low Range 4wd, and for the most of it, High Range 4wd will be fine
    The are always exceptions to the 'rules' as sometimes sand can be like concrete..... however, i would never take mine out of 4wd at Robe in SA ... well you can if you like
  8. #16
    Jan 2018
    2 Post(s)
    Same here. Prado was always in 4wd centre diff locked high.
