Results 1 to 6 of 6
Thread: Tips/help with egr plate
    Jan 2018
    I know there is alot of other posts about the egr plate but i couldnt find one to help me.
    Ive seen on other posts about there being 2 bolts to loosen and then slide the plate down etc
    Haynes booklet shows it as 2 bolts
    Now the problem ive got is that there is 3 bolts (see attached pictured)
    And upon loosening them off there was no movement on the housing therefore i was unable to slide the plate into place.
    I gave it a few gentle taps with a persuasion bar but there was no persuading it to budge. Im guessing that just the constant heat over the years has made it tougher to move.
    Am i doing something wrong?
    Any tips or advice would be greatly appreciated.
    CHEERS IN ADVANCE
    More persuasion required...
    Jan 2018
    I gave it a little
    Was abit scared incase i cracked it somehow
    So bit more weetbix you reckon?
    461 Post(s)
    Is the plate you have to suit where you are showing? Usually the plate sold on Fleabay etc suit the cast EGR pipe where it bolts to the inlet manifold. Much easier there. Just remove the two bolts, get a long screw driver or similar and pry the pipe open just enough to slip out the gasket and in the plate.
    Jan 2018
    Yeh mudski the plate ive got suits that spot. See attached pic
    Mate from work showed me the spot to install it.
    Does it get installed where ive circled red or green. See pic attached.
    461 Post(s)
    Green mate. I wont fit in the other spot.
