28th April 2018, 08:09 PM
#81
SkippyGU
Yeah I feel like getting the motor in is the easiest part and with it being a Nissan motor there is no wondering if it will fit. I think plumbing up everything is gonna be the hardest part. Like the A/C and what not.
Yeah gonna Label the shit out of everything. Because it’s gonna be a long build so I’ll forget
Currently own a ZD30 2000 GU patrol with a dead injector pump
about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
The Following User Says Thank You to JackCollo For This Useful Post:
28th April 2018 08:09 PM
28th April 2018, 08:21 PM
#82
Administrator
Nah that's the fun part mate and you'll learn heaps!
Take your time, get a decent torque wrench, follow the manual, label everything and enjoy!
3rd May 2018, 12:36 AM
#83
SkippyGU
Any brands for torque wrenches
Also any ideas for labelling and sorting, a trip to Bunnings is in order.
3rd May 2018, 06:31 AM
#84
I've Just got a kinchrome one which works fine for most stuff. If you want to do it nice get a small one too for doing smaller stuff under 50nm ish. Not sure about the harmonic balancer might need a big boy for the nut on that they're pretty crazy tight everything else will be right.
When i did the body swap i just used a heap of zip lock bags labeled clearly and put them in a tub. Wires put some masking tape around and label.
How's the machining going?
3rd May 2018, 03:15 PM
#85
Get a Whiteboard and marker or go get a whiteout pen, write on one of the windows, make sure you write all the little jobs down.
That way you can mark off little things and you feel like you're getting somewhere and it doesn't feel as daunting if you're achieving things
Just another Blue over Silver GQ with another TD conversion
The Following 3 Users Say Thank You to Reddave For This Useful Post:
AB (3rd May 2018), JackCollo (3rd May 2018), Rossco (3rd May 2018)
3rd May 2018, 04:41 PM
#86
That's great advice chaps.
A build or at least a refurb on mine is something I'd like to do one day.
Go for it Jack!
Ps. I wish we had a Bunnings over here! Haha
3rd May 2018, 05:24 PM
#87
Smart like tractor
Daveyboyjunior
Go for it Jack!
You do/did! It's not going to well for them apparently
https://www.bunnings.co.uk/our-stores
96 GQ coil/Cab
08 G6eT
Daveyboyjunior (4th May 2018)
3rd May 2018, 05:38 PM
#88
Administrator
Ben-e-boy
Different quality Bunnings snags is killing them!
3rd May 2018, 05:41 PM
#89
SkippyGU
I’ll do some research
Yeah the machining is in the wing at the moment been really busy at work and that so the car hasn’t been touched for a while.
3rd May 2018, 05:43 PM
#90
SkippyGU
I like the ziplock idea might be good for clips and little pieces.
I’ll upload some pictures this weekend when I have time
