Page 1 of 10 123 ... LastLast
Results 1 to 10 of 92
Thread: Build time
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    Build time
    Alright so the time has finally come to start to expensive process of pulling apart the old td42 that has been sitting in the garage for ages and rebuilding it and putting a turbo a 12mm pump and a nice big inter cooler in place of the zd30 which IMO has done bloody marvellously considering it’s the factory motor which did 280,000 with no nads at all factory everything original. It got to 318,975kms in 18 years not bad for a grenade.
    But back to business for internals I was thinking the engines Australia rods and ceramic toped pistons, turbo was thinking a garret gtx3076r, intercooler I was looking at cross country but haven’t decided yet.
    A few things I am uncertain of are
    High flow injectors
    High flow water pump
    High flow oil pump
    That’s all for now for all those interested in following the build along with my mark this thread bc this will be my build thread whenever I get the chance to upload updates I will and lots of pictures.
    Cheers guys for all your help
    Currently own a ZD30 2000 GU patrol with a dead injector pump about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Hi bloke. Thinking that garret 3076 is getting into V8 petty territory.
    I'm running a 2863 and 11mm pump. Lots of pull out of it. Check with @nissannewby for his recommendations re turbo size.
    Beyond that some of the guys are running a Borg Warner to great effect.
    Dec 2016
    Quote Originally Posted by Touses View Post
    There are a few people running really good boost with the 0.64a/r gtx3076 was thinking it was a good size turbo not to small or not to big that it doesn’t make boost for the low down torque
    193 Post(s)
    Hey mate i would seriously coincider Borg Warner for turbo, EFR 6758 is a good size. If your after power and want to future proof it in case you want to tweak it up further down the track i would go for 12mm pump.
    Not sure about high flow injectors think it's more of a wankey catch phrase, more depends I the pressure they are set to crack at which should be done with a tune. Not sure on high flow water pump either mine has a standard one and seems fine.
    Personally prefer front mount intercooler and are a huge amount cheaper that a CC one too. High flow oil pump wouldn't have a clue in that one but would assume standard would be fine depending on how crazy yoy want to go I guess. Also need to think about what you want it for too really, how much power you really need versus reliability / drivrability etc. . .
    193 Post(s)
    Edit: just saw you are planning to run 12mm pump lol.
    Dec 2016
    Yeah true I suppose it’s worth having a look do you know what kind of boost the borg Warner can handle.
    Was thinking of doing the front mount I haven’t seen one on a gu before.
    193 Post(s)
    Up to 30 psi without a drama I believe and past that if you really need it that is. Front mount on GU world be a pisser there's heaps of room in there compared to a GQ at least.
    May 2016
    8 Post(s)
    I have a 600 x300x80mm front mount intercooler .
    Its the way to go try HPT they still make one .
  10. The Following User Says Thank You to Tip12345 For This Useful Post:
    JackCollo (8th March 2018)
  11. #9
    May 2016
    8 Post(s)
    don't forget to look at the valve seats . Watch the valve clearance !
    they tend to disappear ! . its a replacement valve seat does the trick .
    we have had a few come in lately with bad seats ..
  12. #10
    Dec 2016
    Ok that’s what I want to run. With the ability to maybe go into thirties
