Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 92
Thread: Build time
  1. #51
    192 Post(s)
    Hmm, could try Duggan engineering in Reservoir if not there's a couple of places in Bayswater but can't remember names. .
  2. The Following User Says Thank You to Rossco For This Useful Post:
    JackCollo (16th March 2018)
    Liquid nitrogen is a problem due to the rate of contraction on the liner causing micro fractures thus weaking the liner
    Placing the liner in the fridge or freezer prior to install is fine as the liner contracts in a much more controlled manner.
  5. The Following User Says Thank You to nissannewby For This Useful Post:
  6. #53
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    Ok that was my only real worry.
    Thanks guys for clearing that up. I’m gonna be uploading some pictures of the motor soon and the whole process of pulling the old grenade out of the trol
    Currently own a ZD30 2000 GU patrol with a dead injector pump about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
  7. #54
    Dec 2016
    Does anyone have any idea what socket to use for the end caps for the pistons. Can’t seem to get a good grip on one. A 15mm fits but i don’t want to risk getting stuck with a stripped nut
  8. #55
    Dec 2016
    Got the motor and the block apart
  9. #56
    581 Post(s)
    Very good mate, did you take the head off in sequence of the manual?
    Only reason I ask is that there's a specific sequence in undoing the bolts and we, I, some have not followed that before.
  10. #57
    22 Post(s)
    They got roused on too! Lol
    96 GQ coil/Cab
    08 G6eT
  11. #58
    Dec 2016
    Yeah I followed the procedure as best I could
  12. The Following User Says Thank You to JackCollo For This Useful Post:
    AB (20th March 2018)
  13. #59
    192 Post(s)
    How's it all look, how many K's and whats the reason for rebuild? (Sorry might have missed some of it previously)
  14. #60
    Dec 2016
    All good Rossco so basically I bought the motor off a mate it’s got 400,000+kms on the motor and the reason for a rebuild was I’ve always wanted to rebuild one so why not. Also would love to be able to turn the key and know how much effort I put into the motor.
  15. The Following 2 Users Say Thank You to JackCollo For This Useful Post:
    AB (20th March 2018), Rossco (20th March 2018)
