Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 92
Thread: Build time
  1. #81
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    Yeah I feel like getting the motor in is the easiest part and with it being a Nissan motor there is no wondering if it will fit. I think plumbing up everything is gonna be the hardest part. Like the A/C and what not.
    Yeah gonna Label the shit out of everything. Because it’s gonna be a long build so I’ll forget
    Currently own a ZD30 2000 GU patrol with a dead injector pump about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
  2. The Following User Says Thank You to JackCollo For This Useful Post:
    mudski (28th April 2018)
    581 Post(s)
    Nah that's the fun part mate and you'll learn heaps!
    Take your time, get a decent torque wrench, follow the manual, label everything and enjoy!
  5. #83
    Dec 2016
    Any brands for torque wrenches
    Also any ideas for labelling and sorting, a trip to Bunnings is in order.
  6. #84
    192 Post(s)
    I've Just got a kinchrome one which works fine for most stuff. If you want to do it nice get a small one too for doing smaller stuff under 50nm ish. Not sure about the harmonic balancer might need a big boy for the nut on that they're pretty crazy tight everything else will be right.
    When i did the body swap i just used a heap of zip lock bags labeled clearly and put them in a tub. Wires put some masking tape around and label.
    How's the machining going?
  7. #85
    Dec 2012
    Work
    Get a Whiteboard and marker or go get a whiteout pen, write on one of the windows, make sure you write all the little jobs down.
    That way you can mark off little things and you feel like you're getting somewhere and it doesn't feel as daunting if you're achieving things
    Just another Blue over Silver GQ with another TD conversion
  8. The Following 3 Users Say Thank You to Reddave For This Useful Post:
    AB (3rd May 2018), JackCollo (3rd May 2018), Rossco (3rd May 2018)
  9. #86
    Expert Daveyboyjunior's Avatar
    Feb 2015
    Dartmoor, England
    That's great advice chaps.
    A build or at least a refurb on mine is something I'd like to do one day.
    Go for it Jack!
    Ps. I wish we had a Bunnings over here! Haha
  10. #87
    22 Post(s)
    Quote Originally Posted by Daveyboyjunior View Post
    Go for it Jack!
    You do/did! It's not going to well for them apparently
    https://www.bunnings.co.uk/our-stores
    96 GQ coil/Cab
    08 G6eT
  11. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    Daveyboyjunior (4th May 2018)
  12. #88
    581 Post(s)
    Different quality Bunnings snags is killing them!
  13. The Following User Says Thank You to AB For This Useful Post:
  14. #89
    Dec 2016
    I’ll do some research
    Yeah the machining is in the wing at the moment been really busy at work and that so the car hasn’t been touched for a while.
  15. #90
    Dec 2016
    I like the ziplock idea might be good for clips and little pieces.
    I’ll upload some pictures this weekend when I have time
