Results 1 to 5 of 5
Thread: Fitting an exhaust system
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    Hi Guys
    I am looking at getting a Manta Exhaust with extractors for my n/a 4.2 diesel GQ. How hard would it be for me and my dad to fit? Or do you recommend having it fitted by professionals?
    LINK: https://www.exhaustshop.com.au/perfo...ice&order=DESC
    Td42 coily
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    2 Post(s)
    How much patience do you and your dad have? It’s a pretty straight forward job the hardest part is getting the rusted nuts off. But other than that it should just be a take off put on kind of job. Don’t forget to let the nuts and such soak with wd40 or rp7 or bloody locktite freeze release spray.
    Currently own a ZD30 2000 GU patrol with a dead injector pump about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
    175 Post(s)
    I haven't done one to a GQ but fitted up one on an 3L crd and a 4.2 and they are straight forward.
    It's not rocket science and Jack was spot on. Flood every nut you intend to undo with crd or equivalent, overnight . Especially at turbo end.
    Dec 2016
    2 Post(s)
    I snapped two out of three studs on the back of the turbo bc I was impatient.
    Seeing as its non turbo and your doing extractors as well should be super easy. Just don’t go spraying the wd40 while the motors hot. I’ve made that mistake before as well
  6. #5
    Oct 2017
    WA
    Cheers guys, do I need to remove the inner front guard to fit the extractors?
    Td42 coily
