5th March 2018, 04:52 PM
#21
Administrator
Yeah I'm similar to Bennys figures but didn't say anything as not sure if heavier gu would make much difference.
Only time I was getting 16 litres was towing the 1T pop top.
5th March 2018 04:52 PM
5th March 2018, 05:08 PM
#22
Patrol Goddess
Mines not intercooled, but fully loaded across the simpson desert it averaged 14L/100. Daily driving it averages 11L (without the gas injection)
16L seems excessive ??? And I dont generally drive like a nanna.
KATROL- The 2nd
GU TD42TGi
Silent member 1208
5th March 2018, 05:27 PM
#23
The 747
AB
I get around 15lph towing my small camper but unloaded is more like 12-13, my car is around 3 tonne.
5th March 2018, 05:30 PM
#24
Mine has 33 muds and a roof rack with a 3.5 inch lift.
14.7 l hundred
The muds and roofrack cost about 1.5 ltrs a 100.
5th March 2018, 08:03 PM
#25
Travelling Podologist
31" tyres
2006 TDi42
Touring/towing Tvan/ all up weight around 5 tonnes/rear canopy (wider than cab) with roof mounted solar panels/in Tassie up & down a *lot* of hills/ stock except for 3" exhaust & mild dyno -13psi .....averaging around 16litres/100
A Nomadic Life (Blog)
The Following User Says Thank You to Cuppa For This Useful Post:
5th March 2018, 08:09 PM
#26
Legendary
Going to be interesting to see if I get an improvement in fuel economy I was getting around 18 litres to the hundred I reckon and that's around town but I did get as low as 15 so maybe pump is the problem.
5th March 2018, 08:56 PM
#27
Ben-e-boy
I've never seen that fuel usage on road.
The worst I got was 15lph on my big tune, 12.4lph at 200rwhp and 10.8 at 120rwhp, 11.8 NA
The worst consumption was all related to the pump setup. It had huge amounts of off boost fuel, last time I put it on a bench I reduced the offboost fuel by about 45%
Never got a chance to test it properly though
general obsevation showed an improvement, but no figures to validate.
Seems I stand to be corrected. It was just my observations from speaking with other owners whilst chatting at different workshops. My GU sits just on 3T with full tanks. So its not light.
I do believe mine is in dire need of a decent tune though as my last Christmas trip towing the camper, I had to hit the reserve tank button around 80ks earlier than every other time before doing the same trip. And my water temps were higher than usual too. Coincidence? Im more concerned about the water temps than the fuel usage though...But I have zero time now to get it done so it will just leave it.
5th March 2018, 09:02 PM
#28
Smart like tractor
mudski
On a stone cold start is it a bit grumpy for the first few seconds?
96 GQ coil/Cab
08 G6eT
5th March 2018, 09:06 PM
#29
Ben-e-boy
Only if I haven't driven it for over a week or two. I'll add to my above comment Benny that this is only after since getting new injectors installed too.
5th March 2018, 09:08 PM
#30
Smart like tractor
mudski
Did you get high crack pressure injectors?
96 GQ coil/Cab
08 G6eT
