Results 11 to 20 of 30
Thread: Belvo Twin locked gu coilcab re build
    Looking good mate. can you post another pick of the HiMount winch showing detail of the Drum end? is that a Freespool of some description or just a bearing end home made or something. Its clearly done some work and has a 6HP motor on it and extended Drum so keen to see what else.
    Dec 2016
    Hey mate honestly don't know much about the winch I know it has a 6hp motor extended drum i think the bloke made it his self as he was a boiler maker and it has a pinned free spool.
  4. The Following 2 Users Say Thank You to Belvo For This Useful Post:
    GQtdauto (20th March 2018), MudRunnerTD (13th March 2018)
  5. #13
    Quote Originally Posted by Belvo View Post
    Kool. Yeah looks like a crude bearing end but it would work great and reduce the friction. Can you show me the brake shaft too.
  6. #14
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    Looking alot cleaner now ...luv the tray n barwork
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
  7. #15
    Dec 2016
    The break clutch thing has a bit of movement in it so I think that might need replacing.
  8. #16
    Look at that! That's a cracker mate. Grease nipple on your bearing end. I like it. The brake assembly is on a taper shaft and is supposed to be loose when not engaged. The brake shaft is standard on that winch and has not been upgraded and sghou I'd be considered the weakest link. Clearly done some work. Should serve you well.
  9. #17
    Dec 2016
    Managed to fit new 80 series bump stops in the rear all the nuts snapped so just welded studs to the chassis.
    And also added some 2 inch coils the 5 inch lift was to big.
  10. The Following 4 Users Say Thank You to Belvo For This Useful Post:
    AB (20th March 2018), GQtdauto (20th March 2018), Rossco (20th March 2018), Touses (22nd March 2018)
  11. #18
    Dec 2016
    Just a few updates.
    Installed some fox ifp shocks 10inch from and 12 rears.
    Gonna have to raise my shock mounts to get the most out of them with a 2-3 inch lift.
    And started painting the cab today I've never painted anything before but it seemed to come out alright just a bit orange peely and some dust fell on the roof but hopefuly I can cut all that out.
    And some extra photos of my dodgy extraction fans 1 6 inch in line fan 1 8 inch inline fan.
    And a old ducted heater haha.
    Works alright but could be better.
  12. #19
    May 2016
    8 Post(s)
    looks good like your extraction unit ! what a great idea .I will steal that ... I have to paint mu GU as well as it has the great quality Nissan paint . Mine comes off with the pressure washer !!
    Its a 2005 ! . What sort of paint are you using ? don't have to much fun ...
  13. #20
    Dec 2016
    Mines a 99 and the paint was rubbish it was just peeling of.
    I'm using valspar lic40 I chose it because it's a industrial paint that's tough as and was realy cheap like $200 for 4 liters colour matched with activator and thinners.
    Ended up having a few defects in the paint missed a few spots in the roof and blotchy so I'll. Have to fox that later.
  14. The Following 4 Users Say Thank You to Belvo For This Useful Post:
    MudRunnerTD (9th April 2018), Reddave (11th July 2018), Tip12345 (9th April 2018), Touses (10th April 2018)
