Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Belvo Twin locked gu coilcab re build
    Jul 2016
    Looking good belvo
    Will pop past and check it this week
    Georgie
    Dec 2016
    Work had been slow lately but the past few weeks I kicked in and finished a fair bit painted everything the doors bonnet guards.
    Sand blasted the tray and bullbar.
    Painted tray and bar.
    Re installed interior new windscreen.
    Just need to get a roady and rego it now.
  4. The Following 5 Users Say Thank You to Belvo For This Useful Post:
    AB (11th July 2018), GQtdauto (5th January 2019), MB (12th July 2018), mudski (11th July 2018), Rossco (12th July 2018)
  5. #23
    Dec 2016
    Tray and bullbar on used chain and block to make life easier
  6. The Following 9 Users Say Thank You to Belvo For This Useful Post:
    AB (11th July 2018), GQtdauto (5th January 2019), MB (12th July 2018), mudski (11th July 2018), PeeBee (11th July 2018), Reddave (11th July 2018), Rossco (12th July 2018), Touses (12th July 2018), TPC (17th August 2018)
  7. #24
    Dec 2016
    Finnaly finished after a long 8 month all back together and registered.
    Works done.
    cab and tray re spray.
    New shocks and coils.
    Paint chassis.
    Extended bump stops.
    New windscreen.
    Hybrid radius arms.
    New steering arm.
    New steering dampener.
    New tie rod arm.
    All bushed changed.
    Engine and gear box mounts.
    Swivel hubs re done.
    New front disks and breaks.
  8. The Following 7 Users Say Thank You to Belvo For This Useful Post:
    Avo (16th August 2018), GQtdauto (5th January 2019), MB (15th August 2018), MudRunnerTD (16th August 2018), mudski (16th August 2018), Rossco (15th August 2018), TPC (17th August 2018)
  9. #25
    Dec 2016
    Still need to remove both diff center and replace airlocker seals as they both leak.
    Chuck some 35s on UHF and she's ready to hit the tracks.
  10. The Following User Says Thank You to Belvo For This Useful Post:
  11. #26
    In Moderation
    261 Post(s)
    Nice mate. What are those side indicators off?
  12. #27
    Dec 2016
    Think there off a vt-vy commo made them fit don't quite fit got to cut a few things off them.
  13. The Following User Says Thank You to Belvo For This Useful Post:
  14. #28
    Dec 2016
    Before and after all got 3unch coils to chuck in so it will sit a bit higher and need some 35s
  15. The Following 4 Users Say Thank You to Belvo For This Useful Post:
    Avo (16th August 2018), MB (17th August 2018), Rossco (16th August 2018), TPC (17th August 2018)
  16. #29
    Expert JackoGQYoot's Avatar
    Oct 2017
    Byford
    Very nice. Must be rewarding admiring the (almost) finished product after all the hard work!
    Cheers mate
    '94 Coil Cab TD42 184'000km. Highmount 16G. Custom 3" Straight Thru. 4" lift, 35s, Extended bump stops, XHD drag link, Tough Dog S.D. GU Steering Wheel, BT Head Unit, Ontrack Fab sliders and brushbars.
  17. #30
    Dec 2016
    Few things done since last post installed some 3 inch coils to give me a bit more room for mtz 37s on dynamic beadlocks.
    Also added heavy duty lower arms.
    Front diff guard
    New alloy radiator after old one broke
    New thermostat.
    Boost gauge
    Temp gauge.
    Egt gauge.
    And a few other things.
  18. The Following 2 Users Say Thank You to Belvo For This Useful Post:
    GQtdauto (5th January 2019), jack (5th January 2019)
