12th March 2018, 09:48 PM
Moderator
Looking good mate. can you post another pick of the HiMount winch showing detail of the Drum end? is that a Freespool of some description or just a bearing end home made or something. Its clearly done some work and has a 6HP motor on it and extended Drum so keen to see what else.
Check out my Toy -->
Rogue Dung Beetle
12th March 2018 09:48 PM
13th March 2018, 06:30 PM
MudRunnerTD
Hey mate honestly don't know much about the winch I know it has a 6hp motor extended drum i think the bloke made it his self as he was a boiler maker and it has a pinned free spool.
The Following 2 Users Say Thank You to Belvo For This Useful Post:
GQtdauto (20th March 2018), MudRunnerTD (13th March 2018)
13th March 2018, 08:19 PM
Moderator
Belvo
Kool. Yeah looks like a crude bearing end but it would work great and reduce the friction. Can you show me the brake shaft too.
Rogue Dung Beetle
13th March 2018, 08:40 PM
Expert Dingbat
Looking alot cleaner now ...luv the tray n barwork
Quad-Drive 4WD Club...Western Australia
We're all here coz we ain't all there...
13th March 2018, 09:11 PM
MudRunnerTD
The break clutch thing has a bit of movement in it so I think that might need replacing.
13th March 2018, 09:14 PM
Moderator
Belvo
Look at that! That's a cracker mate. Grease nipple on your bearing end. I like it. The brake assembly is on a taper shaft and is supposed to be loose when not engaged. The brake shaft is standard on that winch and has not been upgraded and sghou I'd be considered the weakest link. Clearly done some work. Should serve you well.
Rogue Dung Beetle
20th March 2018, 07:43 PM
#17
The Following 4 Users Say Thank You to Belvo For This Useful Post:
AB (20th March 2018), GQtdauto (20th March 2018), Rossco (20th March 2018), Touses (22nd March 2018)
8th April 2018, 05:48 PM
#18
9th April 2018, 10:30 AM
#19
looks good like your extraction unit ! what a great idea .I will steal that ... I have to paint mu GU as well as it has the great quality Nissan paint . Mine comes off with the pressure washer !!
Its a 2005 ! . What sort of paint are you using ? don't have to much fun ...
9th April 2018, 06:41 PM
#20
MudRunnerTD (9th April 2018), Reddave (11th July 2018), Tip12345 (9th April 2018), Touses (10th April 2018)
