Results 21 to 30 of 39
Thread: How much solar do I need to run my fridge
    So a 57lt Engel only requires 65W in perfect conditions, while an older Waeco Cf50 also out performs the Waeco CFX50 at 170W compared to 190W.........
    What utter fuckin bollox.........
    Odd how my 120W panel can keep a 100ah battery going running the cfx50 for 7 days during a not too sunny September.
    Should probably add, fridge was set to a temp of 3 degrees, in it's fridge cover. Placed under a gazeebo, so in the shade all day. Ambient temps were approx 18deg during the day, dropping to 5 at night.
  2. The Following User Says Thank You to Clunk For This Useful Post:
    GQtdauto (23rd February 2018)
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    As well as cloud cover affecting your panels efficiency temperature also affects how much power you'll get out of them so on the really hot days with clear sunlight your fridges will cycle more but the panels will produce less .
    I had 600 watt of solar on the caravan roof which easily coped with the the two house batteries but plugging in the 4by to charge the aux battery as well was starting to stretch the capacity .
  5. #23
    194 Post(s)
    I agree with Cuppa and GQtdauto, too many variables to give a one sentence answer. I run 2 off 60w Canon Shade tolerant panels into a 200a/h deep cycle, with current monitoring. The max rated output is 3.88a/panel. I get anywhere from 0.1 to 4.1amps per panel depending on the time of day, the ambient temperature, cloud cover. I try to keep the depth of discharge as minimal as possible to prolong battery life, so when I get to say 12.5V, I start the car and give the battery a booster shot from the alternator. I run my fridge at 1 degC plus minus 0.2degC using a calibrated external controller. I have an old 60L Engel fidge with the old compressor that draws 6amps - the newer compressor draws 4 amps using a smart controller. I also run a thermostatically controlled circulation fan that draws 0.1a and comes on at 35degC and off at 28 degC - this circulates the cabin air to improve the heat transfer process of the fridge. I love these panels as they are glass free and laid on SS sheet - basically indestructable, but Canon have stopped making them now. If going for a panel, look at a shade tolerant panel, probably monocrystalline for the highest efficiency. Mine are fix mounted on the roof rack with a 10" airgap to the roof, so they don't suffer too much from reflected heat, the portable panels are a good option as it allows you to optimse the charge with repositioning/aligment during the day, but for me thats too much effort. Hope this helps. Also, your fridge consumption will increase with ambient temperature, so bear this in mind when doing your calculations, plus you only get abot 5 hrs a day at max radiation, and this is approx 60% of the value the panels are rated at, another allowance required.
  6. #24
    Dec 2016
    Northeast Victoria
    41 Post(s)
    That book that Cuppa refers to I believe the guy recommends something upwards of 250 watt of solar per battery from memory , his reasoning is that on even the bad days you will still get enough to get you through .
    Clunks example makes some sense now he's explained the conditions , Wonnangatta last year was mid to high 30s during the day and close to zero at night , I actually turned the fridges off before going to bed and noticed when I turned them back on in the morning they were colder than when I turned the things off .
    My fridges are both fixed in position though so airflow is always a hassle .
  7. #25
    473 Post(s)
    FWIW a recent 40+ degree long weekend with minimal to none daily cloud up on the border found my 120W Waeco portable panel struggling to pump over say 4.5amps at absolute best. (All panels were struggling there I believe)
    Regularly pooring warmish river water over the panels helped it briefly back to between 6&7Amps according to the clamp meter. Quite tedious work but was trying to keep the icy poles frozen for the kids in one and beers and tucker at 1 degree in the other without too much DOD over 252Amps storage.
    My old DX setup had 240W on the roof and used to make slow ice in the old TrailBlaza beast. Can’t remember ambient temps there then though but still well in the 30’s for sure!
    Excessive ambient heat appears to affect as much as cloud cover in my elecy nuffy learnings so will be expanding panel size again one day too!
  8. The Following 2 Users Say Thank You to MB For This Useful Post:
    GQtdauto (23rd February 2018), Rossco (23rd February 2018)
  9. #26
    581 Post(s)
    Far too many variables for any claims made in this thread to be useful to others. If what someone has works for them that is all that matters. Extrapolating that to other's use without including ALL variables is pretty meaningless.
    The chart itself is nonsense as it only refers 'ideal conditions' & 'allowing for 3 days of poor conditions'. Neither are defined, no ambient temps, no info as to what settings the fridges are set on etc etc. No average sun hours (which vary enormously from north to south & winter to summer) etc etc. What gets someone through for 3 days is totally different to what might be required for a week plus. ie. after 3 days re-charge on mains/gennie? or solar only indefinitely.
    I don't believe those Engel figures, but suspect that the waeco figures are probably close to the mark if based upon an average of say 5 sun hours per day (but who would know - it is not specified). In Vic, it can often be 3 or less.
    Likewise, folk reporting what works for them only quoting solar capacity/battery capacity is similarly misleading, albeit well meaning.
    The real problem is that often folk who want to set up with solar, but know little to nothing about it just want someone else to tell them what they need, without understanding that what they need is very individualised. What works perfectly for one person can prove quite inadequate for another. Patterns of usage are everything! Just copying someone else's set up *may* work, but just as likely *may* not. Any good seller will help the buyer to undertake a a usage & consumption audit looking at all the variables before recommending anything. Anything else is just a shot in the dark.
    Working out what your pattern of usage might be BEFORE setting up can be quite daunting, but it is neccessary to ensure you get what YOU want. Anyone can add up the consumption figures of their various appliances, but working out the usage pattern is the hard part. To be covered you need to have a sense of worst case scenario. How long, where, & when. Far better IMO to over rather than under estimate. Having a bit too much solar or battery capacity costs you in space & weight, Not having enough results in frustration & disappointment.
    I doubt that everyone will share my view. Some may see trying to wing it on a minimalist set up as manageable, but like with many things setting up solar is one of those things where I believe it makes sense to 'do it once & do it right'. A well set up solar system (one that is 'balanced - ie. can bring the batteries back to float every 24 hours) is something which once achieved can bring a little satisfied smile to your face every day. Nothing beats just knowing that you have all the power you need from the sun with virtually no ongoing costs. It's just getting through the first stage which can seem a tad overwhelming ......... but it is worth it........ & whilst there is cost involved the initial outlay can be a lot less that the greater cost of upgrading to what you really needed.
    When tables as posted are produced they can be helpful to give folk an idea ......... but they are a shot in the dark & can mislead. No skin of a sellers nose, as if they have sold you an inadequate system, they've made their sale & can always sell you more to make up an initial shortfall. In the meantime you might've had a lovely 3 weeks away marred by warm beer & a grumpy wife & a battery you've wrecked.
    I'm generally happy to try to help others work out what they need, but doing so involves me asking just as many questions as I get asked. An alternative, which I reckon it is hard to beat is to suggest that folk outlay around $40 on one of Collyn Rivers books on Solar. They are easy to read for the non technically minded but cover all that is required. Even if paying someone else to set up a system for you rather than doing it yourself, getting the understanding that these books gives you would be *very* helpful.
    Christ Cuppa, you had to get all technical and knowledgeable in your posts...lol
    Very true though mate on everything mentioned, like I said, is this Engel advertising or?
  10. #27
    snip... like I said, is this Engel advertising or?
    Not really... soooo in trying to reduce it to one sentence.
    Sawafuji Compressors are very efficient, Danfoss type are not so when all else is equal (cabinet materials, useage, solar energy, etc) getting similar cooling performance out of the Sawafuji system means less power, sometimes a lot less.
  11. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    AB (23rd February 2018), GQtdauto (23rd February 2018), MB (23rd February 2018)
  12. #28
    Perhaps this camping shop sells Engel and not waeco...
  13. The Following User Says Thank You to Winnie For This Useful Post:
  14. #29
    473 Post(s)
    Please excuse my ignorance here ET mate, which compressors are in which fridges?
    We’ve collected many fridge brands over the years from old RB’s faithful ‘TrailBlaza’ to oldish ‘Waeco’ 50’s/60’s/80FF and Engel recent 21L retros. Still do love the ‘TrailBlaza’ the best but man it’s outer size (insulation) is huge, only ute fitting!
  15. The Following User Says Thank You to MB For This Useful Post:
  16. #30
    Brief history lesson opportunity beckons...
    Waaay waaay back in the 50's a mob of Germans were making portable fridges and the compressor of choice was also German, specifically Danfoss.
    Another German, specifically Mr Delt was making this nifty outlandish Compressor that all the other Germans laughed at (more about him later)
    Then a Japanese dude, specifically Mr Sawafuji came and saw one of the German dudes, specifically Mr Engel and said "maaate, they are really awesome fridges you make but I have a radical new compressor that will make 'em even better".
    Mr Engel said "OK lets give it a shot" and dumped Danfoss for Sawafuji and all the other Germans threw sauerkruat at them.
    But Mr Sawafuji was right and Mr Engels' fridges with his Compressor were indeed much more reliable and used less power which was vitally important back before Solar Panels etc when the fridge had to run on Battery alone.
    What many didn't know was the Mr Sawafujis Compressor was actually the design he had bought from M Delt and was German all along.
    Mr Engel got tired of getting showered in Sauerkraut every time he went to the Brewhaus and told Mr sawafuji he wanted to sell Sawafuji Compressors to his mates.
    This pissed Mr Sawafuji off so he bought out Mr Engel but didn't want to upset the apple cart too much so didn't change the name and kept the fridge manufacturing in Germany.
    The other Germans pleaded with Mr Sawafuji to sell them his compressors as well but he told them to stick it up their lederhosen and went on to make an even larger fortune in the great sauerkraut famine of '68
    Soooo, the first few iterations of Engels had Danfoss but from then on Engel (and only Engel) have been 100% Sawafuji.
    Everyone else uses Danfoss or Danfoss clones
    Sawafuji (Delt) compressor design and operation is totally different to the Danfoss style rotary jobbies and the design is locked up rock solid in world wide patents and Sawafuji refuses to licence them out or onsell to this day
  17. The Following 4 Users Say Thank You to the evil twin For This Useful Post:
    AB (23rd February 2018), Hodge (24th February 2018), MB (23rd February 2018), Winnie (23rd February 2018)
